Hass.io on Odroid C2 wont upgrade higher than 107.7
I’m using Hassio for a while but ever since the 108 branche of the core appeared it has been impossible to upgrade. When checking the logs I read:
20-04-29 15:17:18 INFO (MainThread) [supervisor.api.security] /core/update access from core_ssh
20-04-29 15:17:18 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.108.9
20-04-29 15:17:18 INFO (SyncWorker_15) [supervisor.docker.interface] Update image homeassistant/odroid-c2-homeassistant:0.107.7 to homeassistant/odroid-c2-homeassistant:0.108.9
20-04-29 15:17:18 INFO (SyncWorker_15) [supervisor.docker.interface] Pull image homeassistant/odroid-c2-homeassistant tag 0.108.9.
20-04-29 15:23:08 ERROR (SyncWorker_15) [supervisor.docker.interface] Can't install homeassistant/odroid-c2-homeassistant:0.108.9 -> 404 Client Error: Not Found ("no such image: homeassistant/odroid-c2-homeassistant:0.108.9: No such image: homeassistant/odroid-c2-homeassistant:0.108.9").
20-04-29 15:23:08 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
Any suggestions?
Thanks, Alex
Most probable cause : out of disk space.
You can log in to the host ( to the host, not the HA container) and run :
docker pull homeassistant/odroid-c2-homeassistant:0.108.9
And see what error message appears.
Thanks Francis,
Will get myself in the host layer and give your suggestion a try.
