Hass.io on Raspberry Pi 3 model B+
I decided to run a Raspberry Pi 3 model B+ with 160 GB SSD.
super stable running my MQTT, Node-RED and mySQL to log data.
I would like to start using HomeAsstant because of the user-interfaces that can be built as I will be adding 20 Sonoff relays and various magnetic sensors to show opoen/closed doors. For that project I need a slick display and Home Assistant seems like the solution.
When will Hass.io support Raspberry Pi 3 model B+ ?
So I am very exites to start using Home Assistant Hass.io.
(Ps: Else I should install on UBUNTU 16.04 Server and later migrate to Pi3 B+)
Who has advice here?
Thanking in advance for help!
Frits
