Hi guys,
I added Samba yesterday and was immediately able to see the HassIO folder in my network drive, however at some point the little folder has disappeared. I can still access it by clicking on recent items in explorer or typing in
\\hassio
but I would prefer to know if i’ve done something wrong or broken something somehow? Is this a common issue?
I found a similar topic already created and the workaround was to simply type it in the address bar, but i’d prefer that it just works.
here is the massive log:
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
No builtin backend found, trying to load plugin
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
tdb(/var/lib/samba/winbindd_idmap.tdb): tdb_open_ex: could not open file /var/lib/samba/winbindd_idmap.tdb: No such file or directory
tdb(/var/lib/samba/account_policy.tdb): tdb_open_ex: could not open file /var/lib/samba/account_policy.tdb: No such file or directory
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
Added user mitchlowther.
nmbd version 4.8.4 started.
Copyright Andrew Tridgell and the Samba Team 1992-2018
Registered MSG_REQ_POOL_USAGE
added interface wlan0 ip=2001:8003:311e:fe00:479f:552a:3351:ed1d bcast= netmask=ffff:ffff:ffff:ffff::
added interface wlan0 ip=10.0.0.32 bcast=10.0.0.255 netmask=255.255.255.0
making subnet name:10.0.0.32 Broadcast address:10.0.0.255 Subnet mask:255.255.255.0
create_subnets: ignoring non IPv4 interface.
making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
load_lmhosts_file: Can't open lmhosts file /etc/samba/lmhosts. Error was No such file or directory
daemon_ready: STATUS=daemon 'nmbd' finished starting up and ready to serve connections
smbd version 4.8.4 started.
Processing section "[config]"
Processing section "[addons]"
Processing section "[ssl]"
Processing section "[share]"
Processing section "[backup]"
INFO: Profiling support unavailable in this build.
tdb(/var/lib/samba/registry.tdb): tdb_open_ex: could not open file /var/lib/samba/registry.tdb: No such file or directory
daemon_ready: STATUS=daemon 'smbd' finished starting up and ready to serve connections
waiting for connections
Could not find child 35 -- ignoring
Could not find child 37 -- ignoring
Could not find child 39 -- ignoring
Could not find child 41 -- ignoring
Could not find child 43 -- ignoring
Could not find child 45 -- ignoring
Could not find child 47 -- ignoring
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 10.0.0.32
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 10.0.0.32
run_elections: >>> Won election for workgroup WORKGROUP on subnet 10.0.0.32 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 10.0.0.32
Samba name server HASSIO is now a local master browser for workgroup WORKGROUP on subnet 10.0.0.32
Could not find child 49 -- ignoring
check_ntlm_password: authentication for user [mitchlowther] -> [mitchlowther] -> [mitchlowther] succeeded
idmap range not specified for domain '*'
desktop-4n13i3h (ipv4:10.0.0.9:62175) connect to service config initially as user root (uid=0, gid=0) (pid 50)
Failed to fetch record!
pcap cache not loaded
desktop-4n13i3h (ipv4:10.0.0.9:62175) connect to service ssl initially as user root (uid=0, gid=0) (pid 50)
desktop-4n13i3h (ipv4:10.0.0.9:62175) closed connection to service config
desktop-4n13i3h (ipv4:10.0.0.9:62175) closed connection to service ssl
Could not find child 52 -- ignoring
Could not find child 54 -- ignoring
desktop-4n13i3h (ipv4:10.0.0.9:62282) connect to service config initially as user root (uid=0, gid=0) (pid 55)
My gut is telling me it is something to do with ‘SSL = true’
Thank you for your help.
