Hass.io System Log Errors: Suspect they're temporary during boot?
As everything NodeRED appears to be working correctly, I’m suspecting that the following error occurs only during boot up as a result of NodeRED not yet being up and running? Just making sure, if anyone knows. I only posted it once, but it repeats about 6 times before appearing to work.
:information_source: 19-08-29 18:14:30 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
:no_entry_sign: 19-08-29 18:14:25 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
:white_check_mark: 19-08-29 18:14:50 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
:white_check_mark: 19-08-29 18:14:50 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
:white_check_mark: 19-08-29 18:14:51 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
