Hi all,
Not sure if it is because of the update to 0.64.3 or because I changed my DDNS address but now when I run hass --script check_config, this is all I get:
Testing configuration at /home/homeassistant/.homeassistant
After a couple seconds, it goes back to my prompt without any scrolling lines.
Thanks in advance for any assistance.
If there are no errors, then that is the correct response from the script.
If there are errors it will print them.
Yeah, fairly recent. You can use the options for info output if you want to see more.
I don’t know which command would get exactly the old output, but
hass --script check_config --info all
Will spit out everything.
same here. The --info all command give a lot of information but no status on the good / bad config
Yeah, it does. At the top it tells you any errors.
alright, thanks. But what is the reason that the previous green feedback is not there anymore?
