HASS Virtualbox Router issues
Im a virtualbox newbie, but i recently installed HASS as a VM (in bridge mode connection), ive been using it for about 2 months.
I just started to run some other services on the same pc that runs virtualbox. I need to port forward these services, this works perfectly when the VM is off.
However when my VM is on, my router (HUAWEI WiFi AX3) is stupid and can’t port forward based on IP but port forward based on the IP of a mac adress.
So what happens is that i start my VM, which changes the ip of the host on my router, which messes up the port forward.
How can i set my VM so it is seen as its own device on my router?
Fix (make static) your IP addresses.
