I did a release upgrade from Ubuntu 17.04 to 18.04 and now my Hass doesn’t start.
When I do a ’ sudo systemctl status home-assistant.service’ I get this
● home-assistant.service - Home Assistant
Loaded: loaded (/lib/systemd/system/home-assistant.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2017-08-19 01:06:34 CEST; 7min ago
Process: 1382 ExecStart=/srv/homeassistant/bin/hass -c /home/homeassistant/.homeassistant (code=exited, status=1/FAILURE)
Main PID: 1382 (code=exited, status=1/FAILURE)
CPU: 32ms
Aug 19 01:06:34 hass hass[1382]: File “/srv/homeassistant/lib/python3.5/types.py”, line 166, in
Aug 19 01:06:34 hass hass[1382]: import functools as _functools
Aug 19 01:06:34 hass hass[1382]: File “/srv/homeassistant/lib/python3.5/functools.py”, line 23, in
Aug 19 01:06:34 hass hass[1382]: from weakref import WeakKeyDictionary
Aug 19 01:06:34 hass hass[1382]: File “/srv/homeassistant/lib/python3.5/weakref.py”, line 12, in
Aug 19 01:06:34 hass hass[1382]: from _weakref import (
Aug 19 01:06:34 hass hass[1382]: ImportError: cannot import name ‘_remove_dead_weakref’
Aug 19 01:06:34 hass systemd[1]: home-assistant.service: Main process exited, code=exited, status=1/FAILURE
Aug 19 01:06:34 hass systemd[1]: home-assistant.service: Unit entered failed state.
Aug 19 01:06:34 hass systemd[1]: home-assistant.service: Failed with result ‘exit-code’.
I have no clue what the problem is, anyone here who can help me?
