Hassbian installation failure on pi zero
I have been trying to install hassbian for 2 days now, but i still come out empty:
hardware:
-pi Zero with a wifi connection on usb data port
-hdmi connection to monitor
-power supply
software:
-hassbian image 1.5.0
process:
-format sd card
-flash via etcher
-add wpa_supplicat.conf to boot partition
-connect pi to monitor and insert sd card to pi and power it up
-ssh into pi
-enter user pi and password raspberry
I then get the screen below
from there nothing happens, I try:
still not much happens, then I execute:
and I get
I have been looping though this process since friday trying different tips from different blogs but I still do not have: http://hassbian:8123 firing, no after the first boot, and not after trying various tips, good thing is I can SSH to the pi, please assist, I’m at the end of my tether. :woozy_face::woozy_face::woozy_face:
Run sudo hassbian-config install homeassistant --force
Also I don’t use Hassbian try this:
good luck
honikos
Pi zero has no network port, works via wifi port, will try to boot it without monitor after flashing the SD card again, if it does not work I will also run @ludeeus force install suggestion above.
Thanks, It starts downloading packages, but stops halfway, I get the following:
pi@hassbian:~ $ sudo hassbian-config install homeassistant --force
Home Assistant install script for Hassbian.
Copyright(c) 2017 Fredrik Lindqvist <https://github.com/Landrash>.
Changing to the homeassistant user
Creating Home Assistant venv
Changing to Home Assistant venv
Installing latest version of Home Assistant
Requirement already satisfied: setuptools in /srv/homeassistant/lib/python3.5/si        te-packages
Collecting wheel
  Downloading https://files.pythonhosted.org/packages/ff/47/1dfa4795e24fd6f93d5d        58602dd716c3f101cfd5a77cd9acbe519b44a0a9/wheel-0.32.3-py2.py3-none-any.whl
Installing collected packages: wheel
Successfully installed wheel-0.32.3
Collecting homeassistant
  Downloading https://files.pythonhosted.org/packages/f7/cd/c40a195dc47f7894bd4e        e88c466229760afbc6269680041a9b064a65302a/homeassistant-0.84.6-py3-none-any.whl (        3.5MB)
Collecting cryptography==2.3.1 (from homeassistant)
  Downloading https://www.piwheels.org/simple/cryptography/cryptography-2.3.1-cp        35-cp35m-linux_armv6l.whl (820kB)
Collecting astral==1.7.1 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/bb/0c/25701e9afad088d98738        89fba0c45b0fbf8097c7e2ecf8d9b40a71985124/astral-1.7.1-py2.py3-none-any.whl
Collecting PyJWT==1.6.4 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/93/d1/3378cc8184a6524dc929        93090ee8b4c03847c567e298305d6cf86987e005/PyJWT-1.6.4-py2.py3-none-any.whl
Collecting voluptuous-serialize==2.0.0 (from homeassistant)
  Downloading https://www.piwheels.org/simple/voluptuous-serialize/voluptuous_se        rialize-2.0.0-py3-none-any.whl
Collecting bcrypt==3.1.4 (from homeassistant)
Exception:
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.w        hl/urllib3/connectionpool.py", line 594, in urlopen
    chunked=chunked)
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.w        hl/urllib3/connectionpool.py", line 391, in _make_request
    six.raise_from(e, None)
  File "<string>", line 2, in raise_from
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.w        hl/urllib3/connectionpool.py", line 387, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/lib/python3.5/http/client.py", line 1198, in getresponse
    response.begin()
  File "/usr/lib/python3.5/http/client.py", line 297, in begin
    version, status, reason = self._read_status()
  File "/usr/lib/python3.5/http/client.py", line 266, in _read_status
    raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/basecommand.py", line        215, in main
    status = self.run(options, args)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/commands/install.py",        line 353, in run
    wb.build(autobuilding=True)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/wheel.py", line 749,        in build
    self.requirement_set.prepare_files(self.finder)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line        380, in prepare_files
    ignore_dependencies=self.ignore_dependencies))
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line        554, in _prepare_file
    require_hashes
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_install.py",        line 278, in populate_link
    self.link = finder.find_requirement(self, upgrade)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 465,        in find_requirement
    all_candidates = self.find_all_candidates(req.name)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 423,        in find_all_candidates
    for page in self._get_pages(url_locations, project_name):
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 568,        in _get_pages
    page = self._get_page(location)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 683,        in _get_page
    return HTMLPage.get_page(link, session=self.session)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 792,        in get_page
    "Cache-Control": "max-age=600",
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.        whl/requests/sessions.py", line 501, in get
    return self.request('GET', url, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/download.py", line 38        6, in request
    return super(PipSession, self).request(method, url, *args, **kwargs)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.        whl/requests/sessions.py", line 488, in request
    resp = self.send(prep, **send_kwargs)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.        whl/requests/sessions.py", line 609, in send
    r = adapter.send(request, **kwargs)
  File "/srv/homeassistant/share/python-wheels/CacheControl-0.11.7-py2.py3-none-        any.whl/cachecontrol/adapter.py", line 47, in send
    resp = super(CacheControlAdapter, self).send(request, **kw)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.        whl/requests/adapters.py", line 423, in send
    timeout=timeout
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.w        hl/urllib3/connectionpool.py", line 643, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.w        hl/urllib3/util/retry.py", line 315, in increment
    total -= 1
TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'
Deactivating virtualenv
Enabling Home Assistant service
Created symlink /etc/systemd/system/multi-user.target.wants/home-assistant@homea        ssistant.service → /etc/systemd/system/[email protected].
Disabling the Home Assistant install script
Removed /etc/systemd/system/multi-user.target.wants/install_homeassistant.servic        e.
Starting Home Assistant
Checking the installation...
Installation failed...
If you have issues with this script, please say something in the #devs_hassbian        channel on Discord.
@ludeeus it finally worked, I had to force install as per the command you gave me three times, so for the benefit of everyone, here are the steps.
1.I flashed hassbian 1.5.0 as per https://www.home-assistant.io/docs/installation/hassbian/installation/ (not forgetting to place the wpa_supplicant.conf file in the boot partition of the newly flashed sd card)
2. Booted rpi zero headless
3. SSH to rpi zero via putty after about 5 minutes
4. Tried to login to hassbian via 192.168.xx.xxx:8123 to no avail
5. I then ran sudo hassbian-config install homeassistant --force but it had errors, then I ran it again (x2) until it gave no errors and gave confirmation:
Your Home Assistant installation is running at 192.168.68.105:8123 or if preferred http://hassbian.local:8123
To continue have a look at https://home-assistant.io/getting-started/configuration/
  1. It still would not start so I manually launched it as per https://www.home-assistant.io/docs/installation/hassbian/common-tasks/
$ source /srv/homeassistant/bin/activate
$ hass ```
When i logged in via url it was working after this.
