Just as a comment, that might help someone else finding this thread, as I did in my despair.
I was having trouble with a similar error log on a raspberry pi 3. It had worked, and after I had fiddled with completely unrelated things (shell_commands, and scripts, none of which involved anything z wave), it stopped. For me it wasn’t the usb path (that was usb_path: /dev/ttyACM0
, and hadn’t changed from when it worked), and to be honest, I don’t know what it was. At some point I might have done an apt-get update
For me, the solution was to do an apt-get dist-upgrade
The output of my home-assistant.log
was:
17-04-03 21:21:42 ERROR (MainThread) [homeassistant.setup] Error during setup of component zwave
File "/srv/homeassistant/lib/python3.4/site-packages/openzwave-0.3.2-py3.4.egg/openzwave/option.py", line 78, in __init__
raise ZWaveException(u"Can't find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
File "/usr/lib/python3.4/traceback.py", line 181, in format_exception
return list(_format_exception_iter(etype, value, tb, limit, chain))
File "/usr/lib/python3.4/traceback.py", line 146, in _format_exception_iter
for value, tb in values:
File "/usr/lib/python3.4/traceback.py", line 125, in _iter_chain
context = exc.__context__
AttributeError: 'NoneType' object has no attribute '__context__'
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/setup.py", line 192, in _async_setup_component
None, component.setup, hass, processed_config)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py", line 336, in setup
CONF_CONFIG_PATH, default_zwave_config_path))
File "/srv/homeassistant/lib/python3.4/site-packages/openzwave-0.3.2-py3.4.egg/openzwave/option.py", line 81, in __init__
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: 'Zwave Generic Exception : Error when retrieving device /dev/ttyACM0 : [\'Traceback (most recent call last):\\n\', \' File "/srv/homeassistant/lib/python3.4/site-packages/openzwave-0.3.2-py3.4.egg/openzwave/option.py", line 78, in __init__\\n raise ZWaveException(u"Can\\\'t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\\n\', \' File "/usr/lib/python3.4/traceback.py", line 181, in format_exception\\n return list(_format_exception_iter(etype, value, tb, limit, chain))\\n\', \' File "/usr/lib/python3.4/traceback.py", line 146, in _format_exception_iter\\n for value, tb in values:\\n\', \' File "/usr/lib/python3.4/traceback.py", line 125, in _iter_chain\\n context = exc.__context__\\n\', "AttributeError: \'NoneType\' object has no attribute \'__context__\'\\n"]'
17-04-03 21:21:50 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
I just hate googling to find that thread that almost, but not quite, solves your problem. So I hope this will help someone searching…
