Hassio Addon Downgrade
Hi folks,
Unfortunately, the Node Red 3.0.0 addon release is broken on my platform, so I need to roll back to an older version.
Does anyone know if this is possible? If not, I guess I could also create a local repo with the older version and run from there…
Did you get any solution for a downgrade? I myself have the same issue and no clue how to downgrade and nobody seems to be able to help or fix the issue
Easiest solution would be restoring it from a backup.
Nope, best suggestion is to take a snapshot before upgrading anything.
You can do it via the hassio cli. There is a command for downgrading the addon from the cli I’m just not in front of a pc atm.
Do you know the command now? I havent found anything still.
Hi jimpower. Would you mind taking a look at this command? :slight_smile: I’m stuck with a broken appdaemon plugin and need to revert.
Regards
Hey @jimpower , have you made it back to PC yet? I would also like to know of this command
Using the UI, and after upgrading to HA 2021.9.6, I was able to go to Supervisor, Backups and click on an older version of Appdaemon addon backup that I wanted to downgrade to. The restore to this older version (kinda) worked as the version number was confirmed in the Appdaemon Info Page. However I wasn’t able to make the addon start (Authentiation error) but this is another issue altogether.
