Hassio and onewire id
Is there a way to configure DS18B20 with hassio?
I’ve looked at:
and I’ve looked also in this forum founding something like that:
  • platform: onewire
    names:
    28-021581d014ff: “temp 1”
    28-031581f3c8ff: “temp 2”
but with hassio I can’t mount the devices… how can I find the id and configure it with hassio?
You have to add dtoverlay=w1-gpio at the end of the config.txt file on the SD card using your PC . You cant edit it in Hass.io.
Do you if there is a way to find sensors connected to GPIO 4?
I’ve used 2nd raspberry with raspbian installed and I’ve got id from there but still it doesn’t work :frowning:
my code is like this:
  - platform: onewire
    names:
      28-000008d633be: temp
I’m using Hassio and i didn’t add dtoveraly=w1-gpio - when I’m adding that line to config.txt my device doesn’t start (I mean Home Assistant doesnt boot)
you can use ssh to hassio and check what devices are connected on /sys/bus/w1/devices/
try to remove 28-000008d633be: temp from your config and add flag to config.txt. After reboot you should see reading from sensors on home assistant main screen.
I thought there is no root via SSH on hass.io? How can you edit files in /boot/?
Or did you speak of this way?
you do not need root to check /sys/bus/w1/devices/. You can do that using standard ssh addon from official store.
In order to edit files in /boot you need to insert SD card to PC and it should be accessible from there.
Sometimes I think to complicated :wink: Took my old Ubuntu Laptop and edited the file there. Thanks!
I’ve had it with Hassio and trying to set up DS18B20 sensors. I carefully followed the instructions here ‘https://home-assistant.io/components/sensor.onewire/’ but kept getting sensors.yaml errors. I have wasted hours on this trivia.
There is very little help online for setting this up. I think the writers of the component instructions assume everyone is competent at installing these components. With real examples in context it would be easier.
For example: from the component page -
  • platform: onewire
    names:
    some_id: your name
is ‘some_id’ any old ID and why my name ‘Fred Bloggs!’
Trial and error again and again!!!
I’m seriously thinking of migrating to node-red
I’m not pretty sure what’s exactly your problem, but of course you can see my real config:
- platform: onewire
  names:
  10-0008043c9374: Living Room
“some_id” is the ID of your sensor “your name” is the name you want to see in the frontend
Hi, Thanks for your reply.
I found the problem…apparently the sensor can only be connected to one specific I/O pin on the pi: GPIO 4
Is that correct???
I had already allocated GPIO 4 to an output for a relay so I was connecting the data wire to a different GPIO pin and was getting errors constantly. Having to constantly reboot to test.
I did get a bit frustrated with it. :slight_smile: but eventually got it working. I am sticking with HA!
Many thanks for your message
Dominic
What does the link: “Don’t use the mount_dir option.” on https://www.home-assistant.io/components/sensor.onewire/ mean? We don’t have to mount the directory? Then how will the config.txt file be edited?
Can someone please isntruct us how to setup this on hassio on Raspberry Pi3?
I’m able to SSH to my PI, but how should I edit /mnt/boot/config.txt?
when I SSH to my PI I and navigate to mnt folder I see it is empty.
Should I create boot folder and in it add config.txt file?
This is missing in docs.
I recently made a blog post about this as the docs were a bit lacking and it took me some time to find out what to do.
http://inspectmygadgets.com/adding-temp-sensors-to-raspberry-pi-with-hass-io/
Similar issues, I’m new to hassbian, coming from autohab2, I’ve been using these onewire dallas sensors for about a year now. confirming, I have the dtoverlay=w1_gpio set in config and can see the devices in /sys/devices/w1_bus_master1/28* I have 5 listed and all sensing temperature. When I add to configuration.yaml
 -platform: onewire
   names:
    28-000007810d18: Sensor1
    28-0417837fe5ff: Sensor2
    28-041783c434ff: Sensor3
    28-0517907b10ff: Sensor4
    28-051790c0c4ff: Sensor5
I get some errors in the log “Error loading /home/homeassistant/.homeassistant/configuration.yaml: mapping values are not allowed here
in “/home/homeassistant/.homeassistant/configuration.yaml”, line 27, column 9” which maps the “names:”
no success referencing the problem and very help from the logs as you can see. other than just loading a fresh image, the only other thing I have done is add two Sony devices hassbian auto discovered, otherwise my setup is out of the the box. any insight is appreciated
I have tried commenting out the last 4 devices leaving only the one with no luck, same error. I was able to add a system temp so I know something works :slight_smile:
  - platform: command_line
    name: Raspberry Pi Temp
    command: "cat /sys/class/thermal/thermal_zone0/temp"
    unit_of_measurement: "°C"
    value_template: '{{ value | multiply(0.001) | round(1) }}'
The main driver I have moving to HA is a scheduler I can manage from the ui like you would a thermostat. I have a radiant flooring system I’ve installed trying to centralize thermostat and temperature control with multiple sensors. anyway, any like I said any insight is appreciated
The problem with this is your syntax. The issue I found was with the hyphen you placed before platform: command_line
I’ve still not got this to work although what I’ve mentioned has removed the error you were getting.
