I am going nuts with automations in hassio. Here is an automation I am trying.
id: Alarm Triggered
alias: test if notify works
platform: state
entity_id: binary_sensor.neo_coolcam_doorwindow_detector_sensor_2
to: “on”
condition: or
conditions:
condition: state
entity_id: alarm_control_panel.alarm_control_panel
state: armed_home
service: notify_budlyte
message: your home and alarm triggered
condition: state
state: armed_away
The check configuration keep telling me the automation is invalid. I get the following set of messages.
Failed config
automation:
- alias: test if notify works
condition: or
conditions: [source /config/automations.yaml:8]
- action: [source /config/automations.yaml:12]
- data: [source /config/automations.yaml:13]
condition: state
state: armed_home
- action: [source /config/automations.yaml:19]
- data: [source /config/automations.yaml:20]
condition: state
state: armed_away
id: Alarm Triggered
trigger: [source /config/automations.yaml:3]
- platform: state
to: on
Successful config (partial)
automation:
I suspect it is trying to help me figure out what is wrong but I am lost. Can anyone help me.
The first step would be to check the yaml file for spacing etc. but this is difficult to do without using code blocks. See the blue box at the top of your message. The spacing tends to be 2 space characters without any tabs.
I alway past my code int Yaml Lint to make sure it is formatted correctly before trying it. He it is better formatted. Thanks
- id: Alarm Triggered
- platform: state
to: "on"
condition: or
conditions:
- condition: state
state: armed_home
- data:
- condition: state
state: armed_away
- data:
Thanks - I did catch that but still getting error in my automation. I have changed it to just try the “or” condition to make duck simple. Still can’t get a clean config test. Here is my new code. I am about to dump HA and look elsewhere. Is it me or are the diagnostics that bad and of no help. Seems you need to just to hours of testing to get anything done. I always test my code in Yamal Lint to make sure it is structured correctly before testing in HA. Am I the only frustrated one? Any help would be greatly appreciated.
- id: alarm triggered
- platform: state
to: "on"
condition:
condition: or
conditions:
- condition: state
state: armed_away
- conditon: state
state: armed_home
Failed config
automation:
condition: [source /config/automations.yaml:8]
condition: or
conditions: [source /config/automations.yaml:10]
- condition: state
state: armed_away
- conditon: state
state: armed_home
id: alarm triggered
- platform: state
to: on
Your state: armed_home/away should be in single quotes. See if that helps. Checking with Lint just checks the structure not that the code is correct, for instance alarm_control_panel.alarm_control_panel could be alarm_control_panel.house?
Thanks for the reply. Tried that and got same results. Did notice this in the log.
2018-03-10 11:28:49 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [conditon] is an invalid option for [automation]. Check: automation->condition->0->conditions->1->conditon. (See /config/configuration.yaml, line 84). Please check the docs at https://home-assistant.io/components/automation/
I followed that doc but am beginning to think HASSIO may be the problem. May be Or and AND are not working in HASSIO. Below is right out of the doc’s. Only other thing I can think of is there is something wrong with the trigger portion of the automation. Thanks again.
condition:
condition: and
conditions:
- condition: state
entity_id: 'device_tracker.paulus'
state: 'home'
- condition: numeric_state
entity_id: 'sensor.temperature'
below: '20'
