Hassio can not install addon on aarch64
Good evening. Since this evening, I can not install any addon. I tried through ssh without chance. I get the following error when I try to check the list of addons :
core-ssh:~# hassio ad list
Error decoding json invalid character β€˜:’ after top-level value: 403: Forbidden
it seems strange as I can not install any addons as it is reported to be not supported anymore for my arch aarch64 (odroid C2) :
18-10-07 21:25:25 ERROR (MainThread) [hassio.addons.addon] Add-on core_dhcp_server not supported on aarch64
18-10-07 21:25:27 ERROR (MainThread) [hassio.addons.addon] Add-on core_dhcp_server not supported on aarch64
18-10-07 21:28:22 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
18-10-07 21:29:06 ERROR (MainThread) [hassio.addons.addon] Add-on a0d7b954_influxdb not supported on aarch64
18-10-07 21:29:59 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-10-07 21:30:19 ERROR (MainThread) [hassio.addons.addon] Add-on a0d7b954_pi-hole not supported on aarch64
I’m having the same issue, but I can install things just fine. They’re probably two separate issues.
Title changed as I think the issue is more related to the aarch64 issue. I remove one addons installed some days ago and I can not install it anymore (influxdb).
Problem solved but don’t ask me why.
There was a bug in the supervisor prior v134 ( https://github.com/home-assistant/hassio/pull/744 )
Thanks. Got to know that it is not a magical solving :wink:
