Getting this issue every 2-3 days. When the Web Application of home assistant is opened in browser, hassio tab and its addons(configurator) are not available in the side menu.
Kindly help us out in this. Is there any way to get that back?
Attached is the screenshot received.
@eddi89 Upgraded homeassistant using the following linux command: $ pip3 install --upgrade homeassistant
Still not getting hassio on Web UI.
Installed hassio on ubuntu using the following curl command: curl -sL https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install | bash -s
Is there any way to remove it from the following path in the file system and reinstall it: /usr/share/hassio/homeassistant
Moreover, is there any way to restart hassio if it is unavailable on Web UI?
huh? hassio runs in docker. you don’t update that way.
