Hassio, config issue
Does anybody know why this happened?
or a way to fix it, the hassio section is not showing up in my ui now.
Thanks!
Please provide some more info.
When did this occur? After an upgrade or so?
What is your installation method?
This happened last night after a normal restart, Using hassos in a raspberry pi3.
Its strange, everything else is working properly.
Can you check if there is more information in the logs? What is your HassOS, supervisor and Home Assistant version?
018-11-05 07:48:36 WARNING (MainThread) [homeassistant.components.media_player.apple_tv] A <class ‘concurrent.futures._base.TimeoutError’> error occurred:
2018-11-05 07:48:43 ERROR (MainThread) [aiohttp.server] Unhandled exception
File “/usr/local/lib/python3.6/site-packages/aiohttp/web_protocol.py”, line 410, in start
await resp.prepare(request)
File “/usr/local/lib/python3.6/site-packages/aiohttp/web_response.py”, line 300, in prepare
return await self._start(request)
File “/usr/local/lib/python3.6/site-packages/aiohttp/web_response.py”, line 608, in _start
return await super()._start(request)
File “/usr/local/lib/python3.6/site-packages/aiohttp/web_response.py”, line 367, in _start
await writer.write_headers(status_line, headers)
File “/usr/local/lib/python3.6/site-packages/aiohttp/http_writer.py”, line 110, in write_headers
self._write(buf)
File “/usr/local/lib/python3.6/site-packages/aiohttp/http_writer.py”, line 67, in _write
raise ConnectionResetError(‘Cannot write to closing transport’)
ConnectionResetError: Cannot write to closing transport
2018-11-05 07:48:48 ERROR (MainThread) [aiohttp.server] Unhandled exception
self._write(buf)
im not sure if this helps or not, i am on hassio 80.0 not sure what supervisor version as I can’t access hassio section
Well, i just tried to restart and it came back. Strange. Thanks for your help!
