HassIO crashing randomly - access Hass.IO logs?
99% chance it’s either an inadequate power supply of a poor quality SD-Card
I have the same issue. Randomly reboots of the system. It started after installing InfluxDB and Grafana and I also updated to hassio 0.72 (now its 0.72.1). After this reboots, the docker container of InfluxDB keeps beeing down always and cant be started again. Only fix is a full reboot of the pi itself. I am getting then:
18-06-27 10:50:19 ERROR (SyncWorker_0) [hassio.docker] Can't start addon_a0d7b954_influxdb: 500 Server Error: Internal Server Error ("driver failed programming external connectivity on endpoint addon_a0d7b954_influxdb (86d0504d73ba6a0a20f6ec23dcc0b741bebfb98de045ac33818140995fec9732): Bind for 0.0.0.0:8888 failed: port is already allocated")
Is there a sensor for the PI System itself to see its temperature or so. Or how can I see the “crash” message of the system. all hassio … logs command are always cleared
Regards
I started having this issue after updating from 107 to 108. Hassio. This morning I noticed a notification automation sent about 150 notifications between and 8 hour period. I went to disable said notification and then tried to restart the automation which caused hassio to become unresponsive. I will have to manually reboot now. Seems to be related to automatons and possible the time as mentioned below. Any resolution?
