I am super new to this and was following JuanMTech’s tutorial on getting started. I install Configurator and then Samba and everything goes fine. I then have a Sonoff SV that I want to connect and this is where problems begin. The SV will connect to my network and I can see it, but ESPHome cannot. I tried setting a static IP and then the SV wouldn’t connect to my network. I tried setting ESPHome to use ping instead of mDNS even though I have mDNS setup on my router (Edgerouter X) and that didn’t work. This is where the title comes into play after a few times trying this HA turns off and never reconnects. I can see it for a little while on the network, but I can’t use hassio.local or the IP to get to it and a ping returns unresponsive. This happened two times to me at the same spot, while trying to connect the SV. Now I have to reflash the SD card for a third time and start all over. Can anyone please help me get this thing setup and running? Also, last night when I went to the Pi to see what was going on it was extremely hot. I run the Pi in a vented case with the heatsinks so I am guessing something is wrong for it to be that hot. Bad Pi maybe??? Up until trying ESPHome a few times everything works flawlessly. Any help would be appreciated.
