Hassio doesn't start assistant container in docker
I tried to install Hassio on Ubuntu Core Xenial (NanoPi Neo2) and followed the instructions for Ubuntu and docker. It works out to install, but it does not start the hassio assistant container, I see only the supervisor container:
root@NEO2:/home/pi# docker ps
CONTAINER ID        IMAGE                                     COMMAND               CREATED             STATUS              PORTS               NAMES
fbbd88a67a68        homeassistant/aarch64-hassio-supervisor   "python3 -m hassio"   29 minutes ago      Up 29 minutes                           hassio_supervisor
How can I change that so that I can access the installed assistant via the IP adress and web interface?
Cheers,
Bene
