Can you get to the configuration files using Samba?
May be a bad configuration that stops the loading.
If you put it in a PC you need to find configuration.yaml, comment out any recent additions to the file and try to reboot the RPi.
If you have a recent snap shot try to use that.
I also copy all config files to a directory on my PC before I make any major changes. Also I occasionally make a copy of the image on the SD card for backup.
Also if things change on the web page I run a configuration check before restart / reboot of the system. It may tell you about impending doom that you can fix before it happens.
There weren’t any changes before I rebooted it. It’s not even starting an operating system (which is why I can’t even ping it) so it’s not getting as far as loading Home Assistant.
I know someone said they were also having trouble with high capacity cards. I’m using the 32gb noobs one from RS components. I think the consensus seems to be to use the Samsung EVO cards.
LOL!! What size were they? What type of cards do you use? I also have a Sandisk but I seem to see bad things about them mostly in these forums as well.
What is the recommendation?
It’s funny as I was originally running the all-in-one version with Raspbian Jesse and never saw any lockups. However, with the 61.1 of hassio I haven’t had any lockups either.
Would be nice if there were some specific recommendations. Could also be power supply related but at least in my case I am using the Pi supplied official supply for the RPi3 and I don’t have anything else plugged in except ethernet cable.
Two Samsung EVOs, 32GB. So exactly the ones you are referring to. But I guess it really depends on the setup. I’m now using an external MariaDB database, so there’s a lot less load now on the SD. Seems to be working ok now.
