sundrys1
(Radek Magyar)
1
Hello ,
can somebody please help me with install hassio in docker? I am using raspbian on raspberry pi4 ?
I have follow this guide Alternative: install Home Assistant Supervised on a generic Linux host
step by step but when I login to HA the menu hassio on left still missing.
then I have tried install Ubuntu and tried this guide
same issue I can not see hassio menu
for hassio imaga I used this command
sudo su
curl -sL https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh | bash -s – -m raspberrypi4 -d /home/ubuntu/hassio
preparing docker I have used this guide
but still nothing works .
That menu is now named “Supervisor,” do you see that?
also make sure you have:
default_config:
OR
hassio:
OR
discovery:
sundrys1
(Radek Magyar)
4
so the menu is Supervisor ???
YES I see it , but why they change the menu ?
the people are confuse everywhere is hassio in youtube
francisp
(Francis)
5
Don’t rely on youtube for information on Home Assistant. Home Assistant changes so fast the information on youtube is quickly outdated.
