First mesage here! I’m running hassio with some ups and downs for about 1,5 years now. Had quite some problems with faulty SD cards and my old RPI Pi 3 (1GB) wasn’t up to the task annymore. So recentrly upgraded to a RPI 4 (8GB). Setup was quite easy, restored a snapshot and everything worked like a charm!
Until yesterday I switched off the power supply to the router and RPI, from there on I wasn’t able to connect to de webserver anymore (also not possible by app). I know hassio is running because the automations still work (true NodeRed).
First thing I tried was a fresh install on a different SD card (64bit because of the 8GB version), after a few minutes I am able to connect to the webserver again (by using http://xx.xx.xx.xx:8123) and setup Samba and put back some saved snapshots. But when I recover one of the snapshots (older and newer ones) the problem retunes and I am not able to connect to the webserver anymore (NodeRed is running again, because the automations do work). From here I am able to ping the RPI and access it true Samba.
I think I need to retrieve the log files, but I’m not quite sure where to find them without the web interface.
The add-ons I use:
• AppDaemon
• Duck DNS
• ESPHome
• File editor
• Hass.io Google Drive Backup
• MariaDB
• Mosquitto broker
• Node-RED
• Samba share
• Terminal & SSH
• Z-Wave to MQTT
• deCONZ
The RPI gets a static IP address from my router (Experia Box v10A).
What can this be? it is driving me nuts!
Update, i think i found all the logs and system info by means of putty and shh:
System info:
arch: aarch64
audio_input: null
audio_output: null
boot: true
image: homeassistant/raspberrypi4-64-homeassistant
ip_address: 172.30.32.1
last_version: 0.116.4
machine: raspberrypi4-64
port: 8123
ssl: true
version: 0.115.6
version_latest: 0.116.4
wait_boot: 600
watchdog: true
~ $ ha supervisor info
addons:
- description: Expose Home Assistant folders with SMB/CIFS
icon: true
installed: 9.3.0
logo: true
repository: core
slug: core_samba
state: started
version: 9.3.0
- description: Python Apps and HADashboard using AppDaemon 3.x for Home Assistant
icon: false
installed: 4.1.0
logo: false
repository: a0d7b954
slug: a0d7b954_appdaemon3
state: stopped
version: 4.1.0
- description: Free Dynamic DNS (DynDNS or DDNS) service with Let's Encrypt support
icon: true
installed: 1.12.0
logo: true
repository: core
slug: core_duckdns
state: started
version: 1.12.1
- description: ESPHome Hass.io add-on for intelligently managing all your ESP8266/ESP32
devices.
icon: true
installed: 1.14.3
logo: true
repository: 15ef4d2f
slug: 15ef4d2f_esphome
state: started
version: 1.15.2
- description: Simple browser-based file editor for Home Assistant
icon: true
installed: 5.1.0
logo: true
repository: core
slug: core_configurator
state: started
version: 5.1.0
- description: Automatically back up Hass.io snapshots to Google Drive
icon: true
installed: 0.100.0
logo: true
name: Hass.io Google Drive Backup
repository: cebe7a76
slug: cebe7a76_hassio_google_drive_backup
state: started
version: 0.101.3
- description: An Open Source MQTT broker
icon: true
installed: "5.1"
logo: true
repository: core
slug: core_mosquitto
state: started
version: "5.1"
- description: Flow-based programming for the Internet of Things
icon: true
installed: 7.0.0
logo: true
slug: a0d7b954_nodered
state: started
version: 7.2.5
- description: Allow logging in remotely to Home Assistant using SSH
icon: true
installed: 8.5.4
logo: true
name: Terminal & SSH
repository: core
slug: core_ssh
state: started
version: 8.9.1
- description: Fully configurable Z-Wave to MQTT gateway and control panel
icon: true
installed: 0.6.0
logo: true
name: Z-Wave to MQTT
slug: a0d7b954_zwave2mqtt
state: stopped
version: 0.8.1
- description: Control a Zigbee network with ConBee or RaspBee by Dresden Elektronik
icon: true
installed: 5.3.4
logo: true
repository: core
slug: core_deconz
state: stopped
version: 6.4.1
- description: An SQL database server
icon: true
installed: 2.2.1
logo: true
repository: core
slug: core_mariadb
state: started
version: 2.2.1
addons_repositories:
- https://github.com/hassio-addons/repository
- https://github.com/esphome/hassio
- https://github.com/sabeechen/hassio-google-drive-backup
arch: aarch64
channel: stable
debug: false
debug_block: false
diagnostics: null
healthy: true
ip_address: 172.30.32.2
logging: info
supported: true
timezone: Europe/Amsterdam
version: "249"
version_latest: "249"
wait_boot: 5
HA logs:
~ $ ha core logs
target(*args)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 695, in _refresh
self._info[template] = template.async_render_to_info(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 306, in async_render_to_info
render_info._result = self.async_render(variables, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 285, in async_render
return compiled.render(kwargs).strip()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
TypeError: unsupported operand type(s) for +: 'float' and 'str'
2020-10-23 10:30:07 ERROR (MainThread) [homeassistant.helpers.event] Error while processing state changed for sensor.consumption_high_tarif_sensor
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 228, in _async_state_change_dispatcher
hass.async_run_job(action, event)
File "/usr/src/homeassistant/homeassistant/core.py", line 384, in async_run_job
target(*args)
2020-10-23 10:30:07 ERROR (MainThread) [homeassistant.helpers.event] Error while processing state changed for sensor.actual_consumption_sensor
target(*args)
TypeError: unsupported operand type(s) for -: 'float' and 'str'
2020-10-23 10:30:07 ERROR (MainThread) [homeassistant.helpers.event] Error while processing state changed for sensor.actual_delivery_sensor
target(*args)
target(*args)
2020-10-23 10:30:28 DEBUG (MainThread) [surepy] using available ETag: {'Connection': 'keep-alive', 'Accept': 'application/json, text/plain, */*', 'Origin': 'https://surepetcare.io', 'User-Agent': 'Mozilla/5.0 (Linux; Android 7.0; SM-G930F Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/64.0.3282.137 Mobile Safari/537.36', 'Referer': 'https://surepetcare.io/', 'Accept-Encoding': 'gzip, deflate', 'Accept-Language': 'en-US,en-GB;q=0.9', 'X-Requested-With': 'com.sureflap.surepetcare', 'Authorization': 'Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJodHRwczovL2FwcC5hcGkuc3VyZWh1Yi5pby9hcGkvYXV0aC9sb2dpbiIsImlhdCI6MTYwMzQ0MDkzOSwiZXhwIjoxNjM0ODkwNTM5LCJuYmYiOjE2MDM0NDA5MzksImp0aSI6IjBGcnh4S0Z1NjJDc0VQdzkiLCJzdWIiOjU3MDY3LCJwcnYiOiJiM2VkM2RiMzM0YzJiYzMzYjE4NDI2OTQ3NTU3NTZhM2ZmYmY1YTdkIiwiZGV2aWNlX2lkIjoiMTUzMjU4ODU3MCJ9.axbpxrYTANIgrMi5IE2--CL2ull6q4hhYIE3UaOm8vI', 'ETag': 'Fw9gQ69vQV0D+wkZE09iczLJrig='}
2020-10-23 10:30:29 DEBUG (MainThread) [surepy] using available ETag: {'Connection': 'keep-alive', 'Accept': 'application/json, text/plain, */*', 'Origin': 'https://surepetcare.io', 'User-Agent': 'Mozilla/5.0 (Linux; Android 7.0; SM-G930F Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/64.0.3282.137 Mobile Safari/537.36', 'Referer': 'https://surepetcare.io/', 'Accept-Encoding': 'gzip, deflate', 'Accept-Language': 'en-US,en-GB;q=0.9', 'X-Requested-With': 'com.sureflap.surepetcare', 'Authorization': 'Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJodHRwczovL2FwcC5hcGkuc3VyZWh1Yi5pby9hcGkvYXV0aC9sb2dpbiIsImlhdCI6MTYwMzQ0MDkzOSwiZXhwIjoxNjM0ODkwNTM5LCJuYmYiOjE2MDM0NDA5MzksImp0aSI6IjBGcnh4S0Z1NjJDc0VQdzkiLCJzdWIiOjU3MDY3LCJwcnYiOiJiM2VkM2RiMzM0YzJiYzMzYjE4NDI2OTQ3NTU3NTZhM2ZmYmY1YTdkIiwiZGV2aWNlX2lkIjoiMTUzMjU4ODU3MCJ9.axbpxrYTANIgrMi5IE2--CL2ull6q4hhYIE3UaOm8vI', 'ETag': 'nSG0Hv5PviAc2Oiy5x7DAPBSxog='}
2020-10-23 10:30:29 DEBUG (MainThread) [surepy] using available ETag: {'Connection': 'keep-alive', 'Accept': 'application/json, text/plain, */*', 'Origin': 'https://surepetcare.io', 'User-Agent': 'Mozilla/5.0 (Linux; Android 7.0; SM-G930F Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/64.0.3282.137 Mobile Safari/537.36', 'Referer': 'https://surepetcare.io/', 'Accept-Encoding': 'gzip, deflate', 'Accept-Language': 'en-US,en-GB;q=0.9', 'X-Requested-With': 'com.sureflap.surepetcare', 'Authorization': 'Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJodHRwczovL2FwcC5hcGkuc3VyZWh1Yi5pby9hcGkvYXV0aC9sb2dpbiIsImlhdCI6MTYwMzQ0MDkzOSwiZXhwIjoxNjM0ODkwNTM5LCJuYmYiOjE2MDM0NDA5MzksImp0aSI6IjBGcnh4S0Z1NjJDc0VQdzkiLCJzdWIiOjU3MDY3LCJwcnYiOiJiM2VkM2RiMzM0YzJiYzMzYjE4NDI2OTQ3NTU3NTZhM2ZmYmY1YTdkIiwiZGV2aWNlX2lkIjoiMTUzMjU4ODU3MCJ9.axbpxrYTANIgrMi5IE2--CL2ull6q4hhYIE3UaOm8vI', 'ETag': 'fBI+c1INaP9GShKjAdzbzhuOyCc='}
2020-10-23 10:30:51 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at 172.30.33.4
2020-10-23 10:30:51 WARNING (MainThread) [homeassistant.config_entries] Config entry for deconz not ready yet. Retrying in 80 seconds
Supervisor logs:
~ $ ha supervisor logs
20-10-23 08:14:45 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
20-10-23 08:14:45 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_cli application
20-10-23 08:14:46 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI homeassistant/aarch64-hassio-cli with version 2020.10.0 - 172.30.32.5
20-10-23 08:14:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-observer with version 2020.10.1
20-10-23 08:14:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-multicast with version 3
20-10-23 08:14:46 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
20-10-23 08:14:46 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_multicast application
20-10-23 08:14:47 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast homeassistant/aarch64-hassio-multicast with version 3 - Host
20-10-23 08:14:47 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
20-10-23 08:14:47 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/raspberrypi4-64-homeassistant with version 0.115.6
20-10-23 08:14:47 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 11 Home Assistant secrets
20-10-23 08:14:47 INFO (MainThread) [supervisor.hassos] Detect HassOS 4.13 / BootSlot A
20-10-23 08:14:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
20-10-23 08:14:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
20-10-23 08:14:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/cebe7a76 repository
20-10-23 08:14:48 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/15ef4d2f repository
20-10-23 08:14:48 INFO (MainThread) [supervisor.store] Loading add-ons from store: 70 all - 70 new - 0 remove
20-10-23 08:14:48 INFO (MainThread) [supervisor.addons] Found 12 installed add-ons
20-10-23 08:14:48 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-mariadb with version 2.2.1
20-10-23 08:14:48 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-deconz with version 5.3.4
20-10-23 08:14:48 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to hassioaddons/node-red-aarch64 with version 7.0.0
20-10-23 08:14:48 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-mosquitto with version 5.1
20-10-23 08:14:48 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-ssh with version 8.5.4
20-10-23 08:14:48 INFO (SyncWorker_7) [supervisor.docker.interface] Attaching to esphome/esphome-hassio-aarch64 with version 1.14.3
20-10-23 08:14:48 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to sabeechen/hassio-google-drive-backup-aarch64 with version 0.100.0
20-10-23 08:14:48 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to hassioaddons/zwave2mqtt-aarch64 with version 0.6.0
20-10-23 08:14:48 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 5.1.0
20-10-23 08:14:48 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-duckdns with version 1.12.0
20-10-23 08:14:48 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-samba with version 9.3.0
20-10-23 08:14:48 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to hassioaddons/appdaemon3-aarch64 with version 4.1.0
20-10-23 08:14:48 INFO (MainThread) [supervisor.snapshots] Found 7 snapshot files
20-10-23 08:14:48 INFO (MainThread) [supervisor.discovery] Loaded 2 messages
20-10-23 08:14:48 INFO (MainThread) [supervisor.ingress] Loaded 1 ingress sessions
20-10-23 08:14:49 INFO (MainThread) [__main__] Running Supervisor
20-10-23 08:14:49 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
20-10-23 08:14:49 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
20-10-23 08:14:49 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 2 add-ons
20-10-23 08:14:49 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
20-10-23 08:14:51 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mosquitto with version 5.1
20-10-23 08:14:51 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning addon_core_mariadb application
20-10-23 08:14:54 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mariadb with version 2.2.1
20-10-23 08:14:54 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
20-10-23 08:14:58 INFO (MainThread) [supervisor.services.modules.mysql] Set core_mariadb as service provider for MySQL
20-10-23 08:14:59 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 4 add-ons
20-10-23 08:14:59 INFO (SyncWorker_6) [supervisor.docker.interface] Cleaning addon_core_samba application
20-10-23 08:15:00 INFO (SyncWorker_6) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-samba with version 9.3.0
20-10-23 08:15:00 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning addon_core_duckdns application
20-10-23 08:15:02 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-duckdns with version 1.12.0
20-10-23 08:15:02 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning addon_core_ssh application
20-10-23 08:15:04 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-ssh with version 8.5.4
20-10-23 08:15:04 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning addon_core_deconz application
20-10-23 08:15:07 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-deconz with version 5.3.4
20-10-23 08:15:12 INFO (SyncWorker_1) [supervisor.docker.interface] Starting homeassistant
20-10-23 08:15:12 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
20-10-23 08:15:39 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
20-10-23 08:15:45 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
20-10-23 08:15:45 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 4 add-ons
20-10-23 08:15:45 INFO (SyncWorker_6) [supervisor.docker.interface] Cleaning addon_15ef4d2f_esphome application
20-10-23 08:15:46 INFO (SyncWorker_6) [supervisor.docker.addon] Starting Docker add-on esphome/esphome-hassio-aarch64 with version 1.14.3
20-10-23 08:15:46 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning addon_core_configurator application
20-10-23 08:15:48 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-configurator with version 5.1.0
20-10-23 08:15:48 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_cebe7a76_hassio_google_drive_backup application
20-10-23 08:15:48 INFO (MainThread) [supervisor.api.security] /host/info access from 15ef4d2f_esphome
20-10-23 08:15:52 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on sabeechen/hassio-google-drive-backup-aarch64 with version 0.100.0
20-10-23 08:15:52 INFO (SyncWorker_7) [supervisor.docker.interface] Cleaning addon_a0d7b954_nodered application
20-10-23 08:15:53 INFO (SyncWorker_7) [supervisor.docker.addon] Starting Docker add-on hassioaddons/node-red-aarch64 with version 7.0.0
20-10-23 08:15:58 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-10-23 08:15:58 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-10-23 08:15:58 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-10-23 08:15:58 INFO (MainThread) [supervisor.host.info] Updating local host information
20-10-23 08:15:58 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
20-10-23 08:15:59 INFO (MainThread) [supervisor.host.services] Updating service information
20-10-23 08:15:59 INFO (MainThread) [supervisor.host.network] Updating local network information
20-10-23 08:16:00 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_nodered
20-10-23 08:16:00 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-10-23 08:16:02 INFO (MainThread) [supervisor.api.security] /homeassistant/info access from cebe7a76_hassio_google_drive_backup
20-10-23 08:16:02 INFO (MainThread) [supervisor.api.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
20-10-23 08:16:02 INFO (MainThread) [supervisor.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
20-10-23 08:16:02 INFO (MainThread) [supervisor.api.security] /snapshots/d03b39b2/info access from cebe7a76_hassio_google_drive_backup
20-10-23 08:16:02 INFO (MainThread) [supervisor.api.security] /snapshots/7089d3c3/info access from cebe7a76_hassio_google_drive_backup
20-10-23 08:16:02 INFO (MainThread) [supervisor.api.security] /snapshots/1ca04a27/info access from cebe7a76_hassio_google_drive_backup
20-10-23 08:16:02 INFO (MainThread) [supervisor.api.security] /snapshots/69be8424/info access from cebe7a76_hassio_google_drive_backup
20-10-23 08:16:02 INFO (MainThread) [supervisor.api.security] /snapshots/34946617/info access from cebe7a76_hassio_google_drive_backup
20-10-23 08:16:02 INFO (MainThread) [supervisor.api.security] /snapshots/f69b0dac/info access from cebe7a76_hassio_google_drive_backup
20-10-23 08:16:02 INFO (MainThread) [supervisor.api.security] /snapshots/9b1d44d8/info access from cebe7a76_hassio_google_drive_backup
20-10-23 08:16:03 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_nodered
20-10-23 08:16:34 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
20-10-23 08:16:34 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
20-10-23 08:16:34 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
20-10-23 08:18:51 INFO (MainThread) [supervisor.api.security] /core/info access from core_ssh
20-10-23 08:19:07 INFO (MainThread) [supervisor.api.security] /core/logs access from core_ssh
20-10-23 08:27:10 INFO (MainThread) [supervisor.api.security] /core/check access from core_ssh
20-10-23 08:27:10 INFO (SyncWorker_6) [supervisor.docker] Runing command 'python3 -m homeassistant -c /config --script check_config' on homeassistant/raspberrypi4-64-homeassistant
20-10-23 08:27:43 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant config is valid
20-10-23 08:28:29 INFO (MainThread) [supervisor.api.security] /supervisor/info access from core_ssh
20-10-23 08:31:06 INFO (MainThread) [supervisor.api.security] /core/logs access from core_ssh
20-10-23 08:31:58 INFO (MainThread) [supervisor.api.security] /supervisor/logs access from core_ssh
Martin.
