I have schedule to restart my Synology router time after time.
Hassio was not affected on WiFi channel, but then I decide to connect it over Ethernet directly to router got this issue too
Hassio became unacceptable with IP or DNS name in browser, but for some reason it accessible over SSH (ipv6 I suppose)
Just edit file /etc/NetworkNamager/system-connections/[config file name] over SSH with remark example provided, and it fixed my issue
Just a confirmation that this is STILL a problem as of now (end of June 2020) with the latest version of Home Assistant on a Pi 4B. Iāve had to power cycle the Pi every time the router is reset.
As to use cases for rebooting the router:
On very rare occasions it will go out to lunch. It went out to lunch yesterday or today after being up for 1-2 months straight.
Firmware upgrades. If you happen to try and live on the bleeding edge with OpenWRT from git master, you might be flashing relatively often. This is the root cause for the second failure of Home Assistant to come back up on the network.
It drops off the network as far as DHCPv4 (no lease shown any more), there is an active DHCPv6 lease. This is, like all others, with wired and not wireless. Also, like everyone else - no other device on the network behaves like this.
Yeah I confirm that as of Aug 12th, 2020 this issue is still the case.
After router reboot.
My Pi4 just canāt be reach even via IP address.
the log goes āLink lost; Power save enabled.ā that is fine, but then after router is up, my Hassio should detect that and pick it up.
and that is with wired connection + Static IP Address.
Router is TP-Link Archar C3200.
update: I unplug the Ethernet and re-plug, nothing happens.
Update:
Then fix by making a Wi-Fi profile USB stick and plug that in. Then unplug the Ethernet cable, count to 10, then re-plug. Now itās working, accessible via static IP address.
I have a timer to turn off router daily during sleep when no one is using WiFi.
Today the elecricity went down and the raspberry apparently rebooted before the wifi connection was ready.
The strange thing is that Home Assistant DOES work, since my devices are accessible and perfcectly working through Google Home or Homekit, which rely on the home assistant MQTT bridge and other things. But I cannot acces the Home Assistant interface neither via desktop nor through the iOS app, same thing with DDNS domain and internal static IP addres (that, as i can see from the router, is the same as always).
Any ideas? It is pretty serious as I had to reboot the entire raspberry to make it work again, and it is pretty annoying since if Iām away and this happens again i would not have any chance unless to open the SSH port on my router, which is the last thing i would do!!
Same here, on HA supervisor, ubuntu LTS, NUC+SSD+ gigabit LAN.
HA will permanent ālostā connection (or hang) after I reboot my ASUS XT8 mesh router.
I suspect the HAās spammed & wait for network response and congested the systemā¦or LAN because I use HA for data center server monitoring, ping test, AI server (another machine over lan) for image processing and fetching data from internet.
Am running Home assistant blue and every time my Linksys Velop router restart i lose connection to my Home assistant. The only way I have to unplug it from the electricity and back on.
I am using two instances of home assistant and the two instances are connected via Ethernet, one live on the main router and the other on a secondary node (Aimesh)
An instance in a Proxmox VM
An instance on Raspberry Pi 2B +
The problem is the same on both instances ! (Home Assistant OS updated on both instances)
If I restart the router, the main instance (VM Proxmox is no longer accessible, I have to restart the VM)
If I restart the secondary node (Aimesh) the secondary instance (Raspberry Pi 2B +) is no longer accessible, I must restart the Raspberry manually).
It is very annoying in the event of a power cut, especially on my secondary instance which does not have a backup battery, the Raspberry starts up before the AiMesh node and therefore the Raspberry must always be restarted manually ā¦
On my main instance, there was a fairly long power failure recently which drained my backup battery, when the power returned home assistant started before my ASUS router, and of course my VM had to be restarted manually.
In case of absence it is not reassuring at all, I do not understand that it can be so. thank you
