HASSIO newbie: iMac <> SSH issues
Hello everyone,
please help - I am not able to edit my config anymore (no SSH connection).
I reinstalled a few days before (from Hassbian to HASSIO). Everything worked well but since today my iMac won’t open SSH anymore. I installed SSH following the suggested steps:
https://home-assistant.io/addons/ssh/
https://help.github.com/articles/generating-a-new-ssh-key-and-adding-it-to-the-ssh-agent/
https://help.github.com/articles/adding-a-new-ssh-key-to-your-github-account/
Up to yesterday my SSH client was able to connect to the RPi. Today there are two issues:
  • SSH connection attemps will timeout (“Could not establish a connection - please check login credentials”)
  • The web frontend HASSIO.local won’t open in Safari anymore. (“Could not open because Server does not answer”)
Please help - what may I do?
Thanks in advance!!
58
This is an extract from Konsole.app when trying to open HASSIO.local in Safari:
Nov 27 18:01:13 iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Nov 27 18:01:13 iMac com.apple.WebKit.WebContent[1554]: objc[1554]: Class AMSupportURLConnectionDelegate is implemented in both /System/Library/PrivateFrameworks/EmbeddedOSInstall.framework/Versions/A/EmbeddedOSInstall (0x7fff8b80b748) and /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice (0x162c85008). One of the two will be used. Which one is undefined.
Please help - what may I do to edit my config again?
May the SSH issue relate to the update to 0.58.1?
I restarted my router - this resolved my issues!
