I can successfully route both directions via the cli, however home assistant (192.168.2.149) refuses to respond on 8123 if the request comes from my haproxy instance (10.20.192.1). Ping works both ways no problems, I can reach haproxy’s service ports with netcat from home assistant, and my ip_bans.yaml file is empty. Requests directly from the 192.168.2.0/24 network work fine.
I’ve verified with tcpdump that the request is being sent to the home assistant, and I have tried adjusting the “trusted_proxies” to both the specific haproxy address being used and the entire 10.20.192.0/24 network.
17:08:33.853866 IP 10.20.192.1.42678 > 192.168.2.149.8123: Flags [S], seq 2183108041, win 64860, options [mss 1380,sackOK,TS val 41961803 ecr 0,nop,wscale 7], length 0
http:
use_x_forwarded_for: true
trusted_proxies:
- 192.168.2.0/24
- 10.20.192.0/24
ip_ban_enabled: false
login_attempts_threshold: 5
