if you can get ssh in, maybe you should run some commands like ‘hassio host reboot’ or ‘hassio ha restart’. I think there’s another command to check status of HA, I forget. Good luck with everything.
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
162eb544b08c homeassistant/qemux86-64-homeassistant “/bin/entry.sh pytho…” 15 hours ago Created homeassistant
Unable to find image '162eb544b08c:latest' locally
Error response from daemon: pull access denied for 162eb544b08c, repository does not exist or may require 'docker login'.
Error response from daemon: could not copy source hosts file /etc/hosts to /var/snap/docker/common/var-lib-docker/containers/162eb544b08c2bffc8081974be7d7f3683a10b381deacc7bfcbf3e3a94e23baa/hosts: write /var/snap/docker/common/var-lib-docker/containers/162eb544b08c2bffc8081974be7d7f3683a10b381deacc7bfcbf3e3a94e23baa/hosts: no space left on device
