Hassio observer keeps crashing on Synology DS718+
I am using a Home Assistant Supervisor on my Synology Diskstation 718+ NAS. 2025.05.0. Everything works fine, but my Hassio Observer keeps rebooting every 3 minutes. When I look in the logs of the Hassio Observer Container I only see this:
stderr	2025/05/09 10:21:49 Start webserver on http://0.0.0.0:80
In the Hassio Supervisor I see more info in the Container Log:
[32m2025-05-09 12:25:08.507 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2025.02.0 - 172.30.32.6e[0m
2025/05/09 12:25:03	stderr	e[32m2025-05-09 12:25:03.313 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugine[0m
2025/05/09 12:25:02	stderr	e[32m2025-05-09 12:25:02.280 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning hassio_observer applicatione[0m
2025/05/09 12:24:59	stderr	e[32m2025-05-09 12:24:59.622 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping hassio_observer applicatione[0m
2025/05/09 12:24:59	stderr	e[33m2025-05-09 12:24:59.617 WARNING (MainThread) [supervisor.misc.tasks] Watchdog/Application found a problem with observer plugin!e[0m
And that happens around every 3 minutes.
I have tried reinstalling HA Supervised already following the great tutorials of Marius Hosting How To Install Home Assistant Supervisor on Your Synology NAS – Marius Hosting but this keeps happening.
Hopefully somebody can point me in the right direction for a fix.
This is not exactly supported type of install. For Synology - Docker or HA OS are the only officially supported installs as far as I know.
You can check with the author of tutorial if he has seen these issues.
