HASSIO PC Ideas
I Had HASSIO (12months) run on a PC 4GB 320hard drive very very Happy then It died :frowning: (bad power supply) build other PC
download the intel-Nuc etcher it to usb got PC BOOT usb nothing happen :frowning: thinking was it me put a ubuntu on same USB drive
that BOOTED and installed onto harddrive :smiley: went back to https://www.home-assistant.io/hassio/installation/#alternative-install-on-generic-linux-server and
and used etcher to do it again still no go what am I missing all the screen comes up with is _ flashing
Try constructing your post in sentences, and in some logical explanation with more detail.
Hi Myle
Could you answer these for me? >
  1. Which HA version are you trying to install?
  2. Could you give some details on your PC you are loading to?
  3. Are you installing to an internal HDD or a external (usb) HDD?
I would suggest the Hass.io version: https://github.com/home-assistant/hassos/releases/download/2.11/hassos_intel-nuc-2.11.img.gz
Hass.io image install instructions are here: https://www.home-assistant.io/hassio/installation/
I would suggest you install to an internal HDD. I would take the internal drive, put it in a USB case - and then use etcher to burn the Hass.io image straight onto the drive. Then I would take the drive out of the USB case and place it back in the PC.
Done!
It is pretty easy this way :slight_smile:
  1. acer Aspire x1700 (MCP73T-AD) 2gig RAM
3 internal HDD 320gb lappie drive
didnโ€™t think of doing it this way.
DOING IT RIGHT NOW will get back
THANKS
done that Put a screen on it and all i see is a _ flashing. Harddrive light doing nothing
okโ€ฆ the PC running the hass.io software isnโ€™t really going to show you much.
I would use a mobile app like โ€œFingโ€ to find your hass.io serverโ€™s IP address. Then I would make that a permanent IP address by using the particular feature of your particular router.
Then I would use that IP address adding port 8123 on the end in a browser - from your laptop or the desktop you use. For eg:
http://192.168.86.20:8123/
Then you should get something!
So:
  1. confirm your server is on your network
  2. Identifiy its IP address
  3. Use :8123 to see how the installation went :slight_smile:
Not all computers BIOS are the same
with the HDD with Hassio on it
I plug into my jukebox and everything booted up so happy with the HDD
now to work out why Acer wont boot that HDD and yet the Acer (MCP73T-AD motherboard) will boot wndows10 drive and the LIBREELEC with kodi the jukebox on it
THANKS @brendanheyu pointing down the right track.
Anytime mate -have fun!
