Hassio Problems
Hi all, I just setup Hass.io and I am having the following issues… I also run HA on a standard python environment on another PI and #1 and #2 below do not happen.
  1. my Envisalink doesn’t work with Hassio. 2019-03-27 10:44:17 ERROR (MainThread) [homeassistant.components.envisalink] Could not establish a connection with the Envisalink
  2. I see alot of errors in log file referring to /usr/local/lib/python3.7/site-packages/… but when I look at /usr/local/lib, I only see python3.6. Why does it assume I have python3.7?
having the same problems… envisalink can’t connect. did you get it working?
