Then, I inserted the card into my Raspberry PI 4, plugged in an Ethernet cable (DHCP supported).
However, the system didn’t seem to boot - no blinking green light, no signals on the Ethernet socket lights.
Tried to look for logs in the SD card, but didn’t find anything interesting. My router said the cable was plugged but no IP was assigned. It shouldn’t be a problem as my other RPI4 using Raspbian worked.
Tried the same thing many times but no luck.
Hassio looks to be a black box for me. How can I debug this problem?
I experienced the same thing. I used ethernet cable not WIFI.
But what i found out that that i needed to whait longer after pluging in the power.
It downloads the latest version of Home Assistant and installes this.
I also connected My RPI4 to my tv but now picture. Then i justed scanned my network for IPs to se if i found it. it Showed as HASSIO. Tried to connect with ip:8123 that worked.
I had a similar problem when connected to managed hub via copper/lan. To identify the IP, I first had to wind back the hub to 100M/bits and not utilise auto detect speeds on the port. Once this was done, the IP etc were found each time. Then I was able to go through setting up home automation. It does take some time to broadcast the Hassio onto the network with a more complicated network. Might help if you can lock you router port for the Hassio to a particular speed to at least get you to a configuration stage.
