I have installed hassio supervised in Docker however i have this is error in the logs it says that it is running but it is not I believe it may be because it is amd64, and i am running docker on a RPI4-64. Newbie mistake ? Is there solution or another image that can be installed ?
standard_init_linux.go:219: exec user process caused: exec format error
Hi thanks for advice tried arm64 response was Unable to find image 'homeassistant/arm64-hassio-supervisor:latest' locally docker: Error response from daemon: pull access denied for homeassistant/arm64-hassio-supervisor, repository does not exist or may require 'docker login': denied: requested access to the resource is denied. text
Tried the armv7 latest and this installed with different errors
‘’21-04-15 09:40:19 WARNING (MainThread) [supervisor.plugins.dns] Error on install CoreDNS plugin. Retry in 30sec 21-04-15 09:40:49 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json 21-04-15 09:40:49 WARNING (MainThread) [supervisor.updater] Can't process version data: 'armv7 21-04-15 09:40:49 WARNING (MainThread) [supervisor.plugins.dns] Error on install CoreDNS plugin. Retry in 30sec text’’’
I noticed in the Docker container that it is not giving the port 8123 , on looking at the log of the container there is no port included.
Hi , i am trying to install HA supervised into a docker container, I have tried everything including this scripted with out success. I don’t use Putty but my iMac terminal using sudo - so i think i am doing something right. I will follow this and see what happens.
I have managed to get this sorted up and running , however a problem with MQTT installed/ created but will not run i have tried restarting docker container no luck all other addons seem fine. Any advice would be appreciated.
