I would like to change the time format to 0-24 but I could not find how to configure it.
I have Logbook, History … in AM / PM format, also the calendar starting with Sunday (
Iam using RPI 3, HA version : 74.0, in the configurator I set: time_zone: Europe/Budapest
Can you help me?
if anyone did this ?
Is there a possibility to do such configuration ?
I’ve seen this thread pop up now and again, I’m pretty sure there is no way to configure this to be 24 hour on the graphs. If you are feeling lucky do a google search for this issue with the filter site:home-assistant.io. You’ll find a bunch of threads with this issue, maybe someone found a solution in it.
Now that one doesn’t make sense. I would expect there to be an option to display 24 hour, but it looks like there isn’t! That might be a good enhancement to the component.
Thanks for your respone, Yes I think this would be a good New features to add in New relese
Go to search maybe i will find a way. If I do I will update you.
