File “/usr/lib/python3.6/runpy.py”, line 193, in _run_module_as_main
“main”, mod_spec)
File “/usr/lib/python3.6/runpy.py”, line 85, in _run_code
exec(code, run_globals)
File “/usr/lib/python3.6/site-packages/homeassistant/main.py”, line 374, in
sys.exit(main())
File “/usr/lib/python3.6/site-packages/homeassistant/main.py”, line 349, in main
args = get_arguments()
File “/usr/lib/python3.6/site-packages/homeassistant/main.py”, line 90, in get_arguments
import homeassistant.config as config_util
File “/usr/lib/python3.6/site-packages/homeassistant/config.py”, line 26, in
from homeassistant.util.yaml import load_yaml, SECRET_YAML
File “/usr/lib/python3.6/site-packages/homeassistant/util/yaml.py”, line 11, in
import keyring
File “/usr/lib/python3.6/site-packages/keyring/init.py”, line 6, in
from .core import (set_keyring, get_keyring, set_password, get_password,
File “/usr/lib/python3.6/site-packages/keyring/core.py”, line 14, in
from . import backend
File “/usr/lib/python3.6/site-packages/keyring/backend.py”, line 12, in
import pkg_resources
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 3017, in
@_call_aside
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 3003, in _call_aside
f(*args, **kwargs)
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 3030, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 650, in _build_master
ws = cls()
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 643, in init
self.add_entry(entry)
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 699, in add_entry
for dist in find_distributions(entry, True):
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 2023, in find_on_path
path_item, entry, metadata, precedence=DEVELOP_DIST
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 2432, in from_location
py_version=py_version, platform=platform, **kw
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 2772, in _reload_version
md_version = _version_from_file(self._get_metadata(self.PKG_INFO))
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 2397, in _version_from_file
line = next(iter(version_lines), ‘’)
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 2565, in _get_metadata
for line in self.get_metadata_lines(name):
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 1471, in get_metadata_lines
return yield_lines(self.get_metadata(name))
File “/usr/lib/python3.6/site-packages/pkg_resources/init.py”, line 1468, in get_metadata
return value.decode(‘utf-8’) if six.PY3 else value
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0x80 in position 0: invalid start byte
