Hello everyone. I have a question about hassio(supervisor). I have a rpi3.First i installed home assistant OS on it. Everything was ok i was able to login to rpilocal:8123/lovelace/0 . But when moving to Supervisor(Hassio) page rpilocal:8123/hassio all web page was freezing. I couldn’t find any solution for it. So i did fresh install of Home Assistant Container on rasbian os with docker but it didn’t help i have same issue: When im moving to Supervisor(Hassio) page rpilocal:8123/hassio all web page was freezing:( please tell me what can i do.
Look at your logs.
2021-05-14 12:01:13 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds
2021-05-14 12:01:14 INFO (MainThread) [homeassistant.setup] Setting up recorder
2021-05-14 12:01:14 INFO (MainThread) [homeassistant.setup] Setting up http
2021-05-14 12:01:14 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.1 seconds
2021-05-14 12:01:14 INFO (MainThread) [homeassistant.setup] Setting up system_log
2021-05-14 12:01:14 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds
2021-05-14 12:01:14 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.3 seconds
2021-05-14 12:01:14 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {‘config’, ‘http’, ‘device_automation’, ‘hassio’, ‘cloud’, ‘person’, ‘frontend’, ‘image’, ‘websocket_api’, ‘search’, ‘system_log’, ‘analytics’, ‘api’, ‘webhook’, ‘lovelace’, ‘onboarding’, ‘auth’}
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setting up config
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setting up hassio
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setting up api
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setting up webhook
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setting up auth
2021-05-14 12:01:15 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds
2021-05-14 12:01:16 INFO (MainThread) [homeassistant.setup] Setup of domain config took 1.4 seconds
2021-05-14 12:01:16 INFO (MainThread) [homeassistant.setup] Setting up image
2021-05-14 12:01:16 INFO (MainThread) [homeassistant.setup] Setting up search
2021-05-14 12:01:16 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds
2021-05-14 12:01:16 INFO (MainThread) [homeassistant.setup] Setting up analytics
2021-05-14 12:01:16 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.7 seconds
2021-05-14 12:01:16 INFO (MainThread) [homeassistant.setup] Setup of domain image took 0.1 seconds
2021-05-14 12:01:16 INFO (SyncWorker_0) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa
2021-05-14 12:01:16 INFO (SyncWorker_2) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
2021-05-14 12:01:16 INFO (MainThread) [homeassistant.setup] Setting up person
2021-05-14 12:01:16 INFO (MainThread) [homeassistant.setup] Setup of domain analytics took 0.1 seconds
2021-05-14 12:01:16 INFO (SyncWorker_0) [homeassistant.loader] Loaded camera from homeassistant.components.camera
2021-05-14 12:01:16 INFO (SyncWorker_2) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2021-05-14 12:01:16 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.1 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up cloud
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.1 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.1 seconds
2021-05-14 12:01:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2021-05-14 12:01:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up frontend
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.components.http] Now listening on port 8123
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 2.8 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {‘group’, ‘input_datetime’, ‘input_select’, ‘media_source’, ‘trace’, ‘history’, ‘script’, ‘blueprint’, ‘sun’, ‘my’, ‘zone’, ‘counter’, ‘input_number’, ‘mobile_app’, ‘scene’, ‘logbook’, ‘tag’, ‘zeroconf’, ‘rpi_power’, ‘input_boolean’, ‘tts’, ‘updater’, ‘automation’, ‘default_config’, ‘map’, ‘timer’, ‘input_text’, ‘system_health’, ‘dhcp’, ‘ssdp’}
2021-05-14 12:01:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
2021-05-14 12:01:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up group
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up input_datetime
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up input_select
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up media_source
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up trace
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain trace took 0.0 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up history
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up blueprint
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain blueprint took 0.0 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up sun
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up my
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain my took 0.0 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up zone
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up counter
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up input_number
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up scene
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up logbook
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up tag
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up rpi_power
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain rpi_power took 0.0 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up updater
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up map
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up timer
2021-05-14 12:01:18 INFO (MainThread) [homeassistant.setup] Setting up input_text
2021-05-14 12:01:19 INFO (MainThread) [homeassistant.setup] Setting up system_health
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setting up dhcp
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.0 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.0 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setting up sensor
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.hassio
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain group took 4.7 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain media_source took 4.6 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 4.5 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 4.5 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.rpi_power
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setting up automation
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 4.6 seconds
2021-05-14 12:01:23 INFO (SyncWorker_0) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hassio
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setting up script
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain tag took 4.7 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.updater
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.components.binary_sensor] Not adding entity Home Assistant Operating System: Update Available because it’s disabled
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.1 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setting up tts
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.1 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.components.sensor] Not adding entity Home Assistant Operating System: Version because it’s disabled
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.components.sensor] Not adding entity Home Assistant Operating System: Newest Version because it’s disabled
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain input_datetime took 5.0 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 5.1 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain counter took 5.0 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 5.0 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 4.9 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain timer took 4.9 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain input_text took 4.9 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.4 seconds
2021-05-14 12:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 5.1 seconds
2021-05-14 12:01:23 INFO (SyncWorker_0) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2021-05-14 12:01:24 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2021-05-14 12:01:24 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2021-05-14 12:01:24 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds
2021-05-14 12:01:24 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.6 seconds
2021-05-14 12:01:24 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.1 seconds
2021-05-14 12:01:24 INFO (MainThread) [homeassistant.setup] Setting up notify
2021-05-14 12:01:24 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds
2021-05-14 12:01:25 INFO (MainThread) [homeassistant.setup] Setting up default_config
2021-05-14 12:01:25 INFO (SyncWorker_0) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2021-05-14 12:01:25 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2021-05-14 12:01:25 INFO (MainThread) [homeassistant.setup] Setting up stream
2021-05-14 12:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.1 seconds
2021-05-14 12:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.1 seconds
2021-05-14 12:01:25 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 13.03s
2021-05-14 12:01:25 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2021-05-14 12:01:25 INFO (MainThread) [homeassistant.core] Timer:starting
2021-05-14 12:01:25 INFO (SyncWorker_0) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
2021-05-14 12:01:29 INFO (SyncWorker_2) [homeassistant.loader] Loaded upnp from homeassistant.components.upnp
2021-05-14 12:02:52 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [1801782872] Connection closed by client
Of course thats was first thing which i did but i didnt find usefull information there
please help to understood problem…
You’d be surprised how many don’t!!
Try (via ssh) to restart the supervisor
docker restart hassio_supervisor
