Hassio won't give a source on port 443
Hello, I am trying to use duckdns to forward port 443 on hassio. Though hassio does not have source or something to connect to on port 443 for some reason. I confirmed it wasn’t my router by using NIGNX proxy and when I activated it then set the port to 443 on canyouseeme.org it shows there is a service there. however when I try to do it with just duckdns it show there is nothing there. Also if I try using the main port (8123) it will work with duck dns. Another thing I’ve install a whole new instance as well and it still doesn’t work. I am looking for any solution that anyone can provide. thanks
I think you just need to forward port 443 on your router to port 8123 on your HA.
I’ve tried that other, ports too but it seems like there is nothing on port 443
