HASSio won't update
Trying to update from 0.75.2 to 0.77.3, but it simply won’t update. I’ve tried rebooting the Pi, disabling all components. Here is all I get for error:
18-09-08 13:34:25 INFO (MainThread) [hassio.homeassistant] Update HomeAssistant to version 0.77.3
18-09-08 13:34:25 INFO (SyncWorker_16) [hassio.docker.interface] Update docker 0.75.2 with homeassistant/raspberrypi3-homeassistant:0.77.3
18-09-08 13:34:25 INFO (SyncWorker_16) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.77.3.
18-09-08 13:39:59 INFO (SyncWorker_16) [hassio.docker.interface] Tag image homeassistant/raspberrypi3-homeassistant with version 0.77.3 as latest
18-09-08 13:39:59 INFO (SyncWorker_16) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant docker application
18-09-08 13:40:22 INFO (SyncWorker_16) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-09-08 13:40:24 INFO (SyncWorker_16) [hassio.docker.interface] Cleanup docker images: [‘homeassistant/raspberrypi3-homeassistant:0.75.2’]
18-09-08 13:40:47 INFO (SyncWorker_19) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.77.3
18-09-08 13:50:55 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of HomeAssistant startup!
18-09-08 13:50:55 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
18-09-08 13:50:55 INFO (MainThread) [hassio.homeassistant] Update HomeAssistant to version 0.75.2
18-09-08 13:50:55 INFO (SyncWorker_14) [hassio.docker.interface] Update docker 0.77.3 with homeassistant/raspberrypi3-homeassistant:0.75.2
18-09-08 13:50:55 INFO (SyncWorker_14) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.75.2.
18-09-08 13:55:47 INFO (SyncWorker_14) [hassio.docker.interface] Tag image homeassistant/raspberrypi3-homeassistant with version 0.75.2 as latest
18-09-08 13:55:47 INFO (SyncWorker_14) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant docker application
18-09-08 13:56:21 INFO (SyncWorker_14) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-09-08 13:56:21 INFO (SyncWorker_14) [hassio.docker.interface] Cleanup docker images: [‘homeassistant/raspberrypi3-homeassistant:0.77.3’]
18-09-08 13:56:47 INFO (SyncWorker_7) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.75.2
18-09-08 13:58:28 INFO (MainThread) [hassio.homeassistant] Detect a running HomeAssistant instance
18-09-08 13:58:28 INFO (MainThread) [hassio.homeassistant] Successfull run HomeAssistant 0.75.2
