Good morning everyone, since I installed OS17.1 this morning, the native integrations for Shelly and Roborock no longer work. Has anyone else experienced the same issue?
I can’t comment on Shelly but my Roborock integration has no issues under 17.1.
Yes, all my Shelly stuff has stopped working and the integration won’t load. Still trying to debug
Roborock integration is ok, sorry
Anyway, this is a serious issue, the Shelly integration is widely used around the world. Let’s report it to the developers, please. Thank you.
I updated today to 17.1. My Shelly integration and all devices works very well. Sorry, no bug in my system.
Well, it appears to be something local, not a general issue. Did you check the logs to see if there is anything of interest?
Just starting to look at issue, restored backup and that’s OK, so it’s something to do with the new release will look at logs and start to see if I can see what’s going on later today.
I didn’t do anything, and now everything is back to normal
Always a little nervous when there are a few reports of things like this, but I went ahead and did the upgrade to 17.1. No problems with my two Shelly Dimmer 2 switches after the upgrade.
I haven’t seen any of the folks with problems with the Shelly integration mention which Shelly devices they have. I wonder if it’s something with only certain kinds of Shelly devices.
Maybe the update was still updating when you checked and hit the panic button. Often a reboot and self reconfiguration is part of the update process, hence a very close reading of the associated release notes is obligatory.
No problem here, RPi5 HAOS 17.1 and Shelly pro EM 50 device
