HassOS HassIO add-ons keep resetting my config
Hoping someone can help… I am following instructions from Juan Tech at https://www.juanmtech.com/home-assistant-hassos-beginners-guide to build a fresh HassOS install (I have a Hassbian environment which is slowly dying… cannot update Certs and Ness component does not work, Samba is failing…). I have successfully booted the environment and can see some auto detected devices which i am able to use. I am attempting to configure some of the addons and am finding that when i add text to the Configuration box, my custom text is wiped and reset to default when i Save and click Start on the add-on…
As an example, i enter the text as per the instructions on the webpage (i set my user as HA and pass HAP) as per the first part below, click save (remains the same),
“workgroup”: “WORKGROUP”,
“name”: “hassio”,
“guest”: false,
“map”: {
“config”: true,
“addons”: true,
“ssl”: false,
“share”: true,
“backup”: true
“username”: “HA”,
“password”: “HAP”,
“interface”: “wlan0”,
“allow_hosts”: [
“10.0.0.0/8”,
“172.16.0.0/12”,
“192.168.0.0/16”
and when i click Start, the Config changes to the second part
“username”: “HA”,
“password”: “HAP”,
“allow_hosts”: [
“10.0.0.0/8”,
“172.16.0.0/12”,
“192.168.0.0/16”
This happens with Samba and Configurator so far, havent tried others yet… anyone else having the same issue?
Samba share 8.1 has only following :
“username”: “xxxxx”,
“password”: “xxxxx”,
“interface”: “enp5s0”,
“allow_hosts”: [
“10.0.0.0/8”,
“172.16.0.0/12”,
“192.168.1.0/24”
After you enter settings did you click save? Before starting the addon? The settings will be in a different colour if there is an error and they won’t save which would explain what you are seeing.
Thanks for the prompt reply.
I am changing very little in the template text, just to make sure i am not causing the issue… I am literally only updating user and pass, and all text stays black… then i click save, then i click start… Upon clicking start, the text updates to remove the additional fields… It is more evident in the Configurator config, as I enter a user/pass, but when i click save, the whole user/pass section is omitted and then becomes unsecured. All text still remains black
So the text i add is :
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”,
“ssl”: false,
“allowed_networks”: [
“192.168.0.0/16”,
“172.30.0.0/16”
“banned_ips”: [
“8.8.8.8”
“banlimit”: 0,
“ignore_pattern”: [
pycache
“dirsfirst”: false,
“enforce_basepath”: false
Then when i click Start, it updates to:
“dirsfirst”: false,
“enforce_basepath”: false,
“ignore_pattern”: [
pycache
thanks again,
Michael
Well for a start, the configurator app doesn’t use a user/pass anymore - it uses a HA user/pass. Make sure you are using the latest addon and click on reset and than enter only what the prompts allow you.
Samba only wants Workgroup, Username, Password, Interfaces and allow_hosts so your config is invalid.
Now I think it has registered into this brain of mine…
So if I understand correctly, the configs I added were old and have been updated, and as such permit only what is shown in the config box when the add-on is first added or reset.
If this is the case, can I please ask just one final question… (noob in me). If my addresses are in the 10.0.1.x range, what should my allow networks look like? I just don’t understand what the significance of the /x is on the up range.
Thanks again for all your help
10.0.1.0/24 - subnet mask. 8 bits per octet and 3 octets = 3*8=24
Thank you, Will update tonight and try again.
