Hi all,
trying to switch from my Arch Linux “supervised” (deprecated) docker to HassOS, I need to run JellyFin on the same RasPI4 than HassOS, using the /share
directory read-write, pretty much as MotionEyeOS and others already do.
Encouraged by this OpenMediaVault 5 video I used the HassOS Portainer addon to add the JellyFin stack+container with this docker-composer
config:
version: "2.1"
services:
jellyfin:
image: linuxserver/jellyfin
container_name: jellyfin-arch
environment:
- PUID=0
- PGID=0
- TZ=Europe/Rome
- UMASK_SET=022 #optional
volumes:
- /share/JellyFin:/config
- /share/Media:/data
ports:
- 8096:8096
restart: unless-stopped
Temporarily using the SSH addon as Protected=NO
, in HassOS inside the existing /share
I created the directories JellyFin
(empty) and Media
(with a small video within as /share/Media/Movies/mymovie.avi
Below is the error returned regardless of both “Protected=” YES or NO, adding SYS_ADMIN
privilege, chmod 777
and a bunch of unsuccessful composer tricks found on the 'net:
Btw, /share
is mounted rw
on sda
instead of mmc
because the hassos-data
partition is on a SSD:
➜ ~ mount | grep share
/dev/sda1 on /share type ext4 (rw,relatime,stripe=8191)
Please help me sort out this, thanks.
Piero
P.S.: before you suggest Plex, I strongly prefer JellyFin because it gives to me more than enough features, it doesn’t require a registration, and it’s a lot more privacy-savvy than Plex.
Edit: corrected typos.
