HassOs reboot loop
Good morning, everyone,
I find myself in an insoluble problem (probably because I lack experience).
My Home Assistant is installed on a RPI 3 with a tested and functional 2.6A power supply.
Since yesterday my “home assistant” did not answer anymore. I had to physically switch it off.
At reboot it starts normally and arrives without any error on “homeassistant login:”
Problem after about 40 seconds the system reboot.
The information received on the screen is as follows:
[OK] Started Docker Application Container Engine
[OK] Started HassOS Supervisor
[OK] Started Getty on tty1
[OK] Reached target Login Prompts
[OK] Reached target Multi-User System
[OK] Started Update UTMP about system Runlevel Changes
Welcome to Home Assistant
home assistant login : [OK] Stopped target Remote File System
[OK] Stopped target Timers
[OK] Stopped target System Time Synchronization
I really need your help because I don’t know what to do to get out of it.
Thank you in advance.
Arka
