HassOS + Wlan
I am trying to do a new install of HassOS with flashing the image to the SD Card. But now I want to configure WLAN before booting up as I don’t want to use a LAN connection.
What exactly do I have to do? I read about attaching a USB stick with some files and a specific folder structure… Is this really necessary? I do then always have to have the USB stick connected or only for the initial installation?
Thanks for your help.
Thomas
I have not done it myself, but read it on another tread.
  1. Save the file with WLAN information to a USB-stick.
  2. Update your SD-card with HassOS.
  3. Start your RPI.
  4. Then attach the USB-stick.
  5. Within Hassio (Menu: Hassio->System), you find a button saying “Import form USB”. Use this to read the file on the USB-stick.
  6. Remove afterwords the USB-stick.
Did it work?
https://github.com/home-assistant/hassos/blob/dev/Documentation/network.md
The USB drive is only used to pass the configuration to the host. Then you remove it.
It didn’t work for me with the import after a non w-lan install. but it worked fine with a usb stick and the file plugged in during a fresh install. Thanks for your help anyways.
