Hi I have started a small lvgl project using ESP32 2.8 inch 240*320 TFT with Touch. When i run the program, all okay but cannot toggle entity switch.
My yaml:
i2c:
sda: GPIO21 # Orig gpio 27 for 2.8" LCD but for 2.4" gpio 21
scl: GPIO22 # Orig gpio 22 for 2.8" LCD but for 2.4" gpio 22
scan: true
# id: bus_a
spi:
- id: lcd
clk_pin: GPIO14 # Orig gpio 14 for 2.8" LCD but for 2.4" gpio 14
mosi_pin: GPIO13 # Orig gpio 13 for 2.8" LCD but for 2.4" gpio 13
miso_pin: GPIO12 # Orig gpio 12 for 2.8" LCD but for 2.4" gpio 12
# - id: touch
# clk_pin: GPIO25 # Orig gpio 25 for 2.8" LCD but for 2.4" no
# mosi_pin: GPIO32 # Orig gpio 32 for 2.8" LCD but for 2.4" no
# miso_pin: GPIO39 # Orig gpio 39 for 2.8" LCD but for 2.4" no
display:
- platform: ili9xxx
model: ILI9341
spi_id: lcd
cs_pin: 15 # Orig gpio 15 for 2.8" LCD but for 2.4" gpio 15
dc_pin: 2 # Orig gpio 2 for 2.8" LCD but for 2.4" gpio 15
# reset_pin: 3
rotation: 180
invert_colors: false
update_interval: 5s
dimensions:
height: 240
width: 320
touchscreen:
platform: xpt2046
spi_id: lcd
cs_pin: 33 # Orig gpio 33 for 2.8" LCD but for 2.4" gpio 33
# interrupt_pin: 36 # Orig gpio 36 for 2.8" LCD but for 2.4" gpio no
update_interval: 150ms
threshold: 400
calibration: # Setting about for 2.4 " ???
x_min: 200
x_max: 3900
y_min: 200
y_max: 3900
# transform:
# mirror_x: true
# mirror_y: false
# swap_xy: false
output:
- platform: ledc
pin: GPIO27 # Orig gpio 21 for 2.8" LCD but for 2.4" is ok 27
- platform: ledc
pin: GPIO4 # Orig gpio 33 for 2.8" LCD but for 2.4" gpio 4 is ok
inverted: true
- platform: ledc
pin: GPIO16 # Orig gpio 16 for 2.8" LCD but for 2.4" gpio 16 is ok
inverted: true
- platform: ledc
pin: GPIO17 # Orig gpio 17 for 2.8" LCD but for 2.4" gpio 17 is ok
inverted: true
light:
- platform: monochromatic
output: former_led_pin
name: "Display Backlight"
restore_mode: ALWAYS_ON
- platform: rgb
red: output_red
green: output_green
blue: output_blue
restore_mode: ALWAYS_OFF
font:
- file: "gfonts://Roboto"
bpp: 4
extras:
- file: "fonts/materialdesignicons-webfont.ttf"
glyphs: [
"\U000F09AC", # mdi-tool
"\U000F1A4E", # mdi-lightbuld-on-10
"\U000F02E3", # mdi:bed
"\U000F0A00", # mdi:lighthouse-on
"\U000F06E9", # mdi:lightbulb-on-outline
"\U000F0290" # mdi:fridge
binary_sensor:
- platform: homeassistant
entity_id: switch.den_phong_ngu
publish_initial_state: true
on_state:
then:
lvgl.widget.update:
state:
checked: !lambda return x;
- platform: lvgl
widget: bedroom_light
lvgl:
buffer_size: 25%
displays:
- my_display
touchscreens:
- my_touchscreen
pages:
- id: room_page
widgets:
- obj: # a properly placed coontainer object for all these controls
align: CENTER
width: 300
height: 256
x: 4
y: 4
pad_all: 3
bg_opa: TRANSP
border_opa: TRANSP
layout: # enable the FLEX layout for the children widgets
type: FLEX
flex_flow: COLUMN_WRAP # the order of the widgets starts top left
flex_align_cross: CENTER # they sould be centered
widgets:
- label:
text: "Home"
- button:
width: 85 # choose the button dimensions so
height: 64 # they fill the columns nincely as they flow
checkable: true
widgets:
- label:
align: CENTER
text_font: my_font_with_icons
text: "\U000F02E3" # mdi:arrow-up
on_click:
- homeassistant.service:
service: switch.toggle
- logger.log:
format: "Button checked"
- button:
width: 85
height: 64
checkable: true
widgets:
- label:
align: CENTER
text: "\U000F1A4E" # mdi:stop
- button:
width: 85
height: 64
checkable: true
widgets:
- label:
align: CENTER
text: "\U000F06E9" # mdi:arrow-down
- label:
text: "South"
- button:
width: 85
height: 64
checkable: true
widgets:
- label:
align: CENTER
text: "\U000F005D"
- button:
width: 85
height: 64
checkable: true
widgets:
- label:
align: CENTER
text: "\U000F04DB"
- button:
width: 85
height: 64
checkable: true
widgets:
- label:
align: CENTER
text: "\U000F0045"
- label:
text: "West"
- button:
width: 85
height: 64
checkable: true
widgets:
- label:
align: CENTER
text: "\U000F005D"
- button:
width: 85
height: 64
checkable: true
widgets:
- label:
align: CENTER
text: "\U000F04DB"
- button:
width: 85
height: 64
checkable: true
widgets:
- label:
align: CENTER
text: "\U000F0045"
Logs:
[21:23:17.291][D][xpt2046:055]: Touchscreen Update [906, 877], z = 2377
[21:23:17.315][D][binary_sensor:039]: 'button2': New state is ON
[21:23:17.330][W][lvgl:000]: lv_draw_sw_letter: lv_draw_letter: glyph dsc. not found for U+F005D (in lv_draw_sw_letter.c line #105)
[21:23:17.470][D][binary_sensor:039]: 'button2': New state is OFF
[21:23:17.477][D][main:305]: Button checked
[21:23:24.553][D][xpt2046:055]: Touchscreen Update [887, 1056], z = 1882
[21:23:24.578][D][binary_sensor:039]: 'button2': New state is ON
[21:23:24.719][D][binary_sensor:039]: 'button2': New state is OFF
[21:23:24.729][D][main:305]: Button checked
[21:23:28.782][D][xpt2046:055]: Touchscreen Update [894, 1184], z = 1665
[21:23:28.822][D][binary_sensor:039]: 'button2': New state is ON
[21:23:28.969][D][binary_sensor:039]: 'button2': New state is OFF
[21:23:28.982][D][main:305]: Button checked
Anyone can help?
