Is there a fix or a known issue to my problem? everytime i restart home assistant i get kicked out of hangouts. I have to remove the integration and re login with the oath_code to get it resolved
20-09-09 12:10:35 ERROR (MainThread) [homeassistant.util.logging] Exception in async_handle_update_users_and_conversations when dispatching 'hangouts_connected': ()
File "/usr/src/homeassistant/homeassistant/components/hangouts/hangouts_bot.py", line 341, in async_handle_update_users_and_conversations
await self._async_list_conversations()
File "/usr/src/homeassistant/homeassistant/components/hangouts/hangouts_bot.py", line 310, in _async_list_conversations
) = await hangups.build_user_conversation_list(self._client)
File "/usr/local/lib/python3.8/site-packages/hangups/conversation.py", line 30, in build_user_conversation_list
conv_states, sync_timestamp = await _sync_all_conversations(client)
File "/usr/local/lib/python3.8/site-packages/hangups/conversation.py", line 110, in _sync_all_conversations
response = await client.sync_recent_conversations(request)
File "/usr/local/lib/python3.8/site-packages/hangups/client.py", line 672, in sync_recent_conversations
await self._pb_request('conversations/syncrecentconversations',
File "/usr/local/lib/python3.8/site-packages/hangups/client.py", line 413, in _pb_request
res = await self._base_request(
File "/usr/local/lib/python3.8/site-packages/hangups/client.py", line 469, in _base_request
res = await self._session.fetch(
File "/usr/local/lib/python3.8/site-packages/hangups/http_utils.py", line 86, in fetch
raise exceptions.NetworkError(
hangups.exceptions.NetworkError: Request return unexpected status: 401: Unauthorized
And for me as well. But I have found workaround: looks like it is not really necessary to re-login, it is possible to just call service hangouts.reconnect from developer panel. It does not always work from the first time but usually does after a couple attempts.
I also have this issue and from what I read from the Hangups github (used by the Hangouts integration) is that google is testing a new api for hangouts which does not work well with quotes in the authentication cookie.
Requests are probably randomly routed to the new (broken) or old (working) api.
The hangups library has a workaround in version 0.4.11, but home assitant is using 0.4.9 right now.
See this issue in the hangups github: https://github.com/tdryer/hangups/issues/498.
I installed hangups 0.4.11 and things seems to work nicely now.
I am using home assistant container on linux:
SSH to your home assistant host machine.
Find the home assistant container name (in my case it is hass): Docker ps
connect to the container instance: docker exec -it hass bash
go to the hangouts integration folder: cd /usr/src/homeassistant/homeassistant/components/hangouts/
edit the manifest file: vi manifest.json
Change the current hangups version from 0.4.10 (if you are on latest) to 0.4.11: follow sections 5 and 7 to edit and save the version: https://staff.washington.edu/rells/R110/
Restart home assistant (not the container!)
Home assistant will install the new version at bootup. If you restart the container, those changes will be lost. Using the restart button in home assistant web page is fine.
