Ok so I was just able to get a device that can have home assistant running 24/7 but whenever I leave it on for some while it refuses to connect and ii only starts working when I reboot the host from the home assistant cli any reason for this?
I have ha installed using a Vm in a hypervisor with ha os on a mac
Monitor your logs for errors and your system resource use.
Nothing in the logs just that one of my devices keeps connecting and disconnecting
Also even if I keep the dashboard open for some time it says trying to connect and then just doesn’t connect I have to manually open up the MacBook and say host reboot and then only it works
