### The problem
Since upgrading to 2022.7 (0,1,2) the HaveIBeenPwned integrat…ion stopped working. It no longer fetches breached/ non-breached statuses.
The log shows errors as indicated further down in the log-section.
Happy to provide more info/ test things out for you.
### What version of Home Assistant Core has the issue?
2022.07.2
### What was the last working version of Home Assistant Core?
2202.06.x
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
HaveIBeenPwned
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/haveibeenpwned/
### Diagnostics information
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
File "/usr/local/lib/python3.10/site-packages/anyio/streams/tls.py", line 130, in _call_sslobject_method
result = func(*args)
File "/usr/local/lib/python3.10/ssl.py", line 917, in read
v = self._sslobj.read(len)
ssl.SSLWantReadError: The operation did not complete (read) (_ssl.c:2548)
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py", line 33, in read
return await self._stream.receive(max_bytes=max_bytes)
File "/usr/local/lib/python3.10/site-packages/anyio/streams/tls.py", line 195, in receive
data = await self._call_sslobject_method(self._ssl_object.read, max_bytes)
File "/usr/local/lib/python3.10/site-packages/anyio/streams/tls.py", line 137, in _call_sslobject_method
data = await self.transport_stream.receive()
File "/usr/local/lib/python3.10/site-packages/anyio/_backends/_asyncio.py", line 1265, in receive
await self._protocol.read_event.wait()
File "/usr/local/lib/python3.10/asyncio/locks.py", line 214, in wait
await fut
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.10/site-packages/httpcore/_exceptions.py", line 8, in map_exceptions
yield
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py", line 31, in read
with anyio.fail_after(timeout):
File "/usr/local/lib/python3.10/site-packages/anyio/_core/_tasks.py", line 118, in __exit__
raise TimeoutError
TimeoutError
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 60, in map_httpcore_exceptions
yield
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 353, in handle_async_request
resp = await self._pool.handle_async_request(req)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 253, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 237, in handle_async_request
response = await connection.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py", line 90, in handle_async_request
return await self._connection.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 105, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 84, in handle_async_request
) = await self._receive_response_headers(**kwargs)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 148, in _receive_response_headers
event = await self._receive_event(timeout=timeout)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 177, in _receive_event
data = await self._network_stream.read(
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py", line 30, in read
with map_exceptions(exc_map):
File "/usr/local/lib/python3.10/contextlib.py", line 153, in __exit__
self.gen.throw(typ, value, traceback)
File "/usr/local/lib/python3.10/site-packages/httpcore/_exceptions.py", line 12, in map_exceptions
raise to_exc(exc)
httpcore.ReadTimeout
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 205, in _async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 164, in _async_update_data
return await self.update_method()
File "/usr/src/homeassistant/homeassistant/components/luftdaten/__init__.py", line 43, in async_update
await sensor_community.get_data()
File "/usr/local/lib/python3.10/site-packages/luftdaten/__init__.py", line 29, in get_data
response = await client.get(str(url))
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1751, in get
return await self.request(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1527, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1614, in send
response = await self._send_handling_auth(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1642, in _send_handling_auth
response = await self._send_handling_redirects(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1679, in _send_handling_redirects
response = await self._send_single_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1716, in _send_single_request
response = await transport.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 352, in handle_async_request
with map_httpcore_exceptions():
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 77, in map_httpcore_exceptions
raise mapped_exc(message) from exc
httpx.ReadTimeout
2022-07-09 11:12:23 ERROR (SyncWorker_0) [homeassistant.components.haveibeenpwned.sensor] Failed fetching data for [email adress being checked]
### Additional information
_No response_
