Just read this thread and am I correct in understanding that integration for Haverland radiators on a Haverland hub will be supported by this Smartbox integration? Will it be included in the next software release?
If the Haverland Hub is a smartbox (I think it is one), it should work yes !
The next release of this integration will be easier to configure it
Thanks. Yes, it is a smartbox so looking forward to the next release
Yes, Haverland smartbox is already supported
I have the latest software and it’s not supported that I can see so I assume it will be in the next release?
Could you give me more details about your setup, brand, etc?
Brand new Home Assistant Green running the latest software:
- Core 2025.2.2
- Supervisor 2025.02.0
- Operating System 14.2
- Frontend 20250210.0
I mean, about your radiator
Oh, sorry
I have four Haverland ULTRAD smart radiators controlled from a Haverland ULTRAD - SmartBox Wi-Fi Controller
Just to be clear, I can’t see the ‘smartbox’ integration anywhere in my Home Assistant - should I be able to see it or is it coming in the next release?
Do you have HACS installed ?
What is HACS?? Oh, sorry, just googled it. No, not installed but I can see I need it?
Yes, this is the first step
Then, on the next release you will have the todo installation (which is not yet fully automates)
Thank you! I now have HACS installed so I just wait for the next release?
You can already add GitHub - ajtudela/hass-smartbox: Home Assistant integration for Haverland heating smartboxes to the HACS.
Click on the three dots (upper right) > custom repositories > Repository : GitHub - ajtudela/hass-smartbox: Home Assistant integration for Haverland heating smartboxes, Type : Integration
Do not yet download it, wait the really soon next release
Thank you @Delmael - I have added the repository to HACS as you suggested and will wait for the next release before downloading.
Hello everyone
Somme good news, we’ve just released a new version of the smartbox integration
What’s in this 2.1.0 version:
- Every call are now asynchronous as home assistant requirement needs
- The updates of entites are now in real time through the websocket
- Entities are now linked to a device
- Configuration throw the UI : no more need of the basic_auth or url, etc
- Energy consumption sensor and history
- Translations
- Technical and security improvments
You can download it and use it.
If you have any questions look at the README then ask it here or on github
Excellent news and great progress. I have intalled 2.1.0 and connected to my Haverland account but I then get an error:
Error setting up entry Haverland [email protected] for smartbox
and then Smartbox shows:
Failed to set up:
Check the logs.
Here is the log output:
Logger: homeassistant.config_entries
Source: config_entries.py:637
First occurred: 14:39:12 (3 occurrences)
Last logged: 14:46:00
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 637, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/smartbox/__init__.py", line 76, in async_setup_entry
devices = await get_devices(session=session, hass=hass)
File "/config/custom_components/smartbox/model.py", line 395, in get_devices
devices.append(await create_smartbox_device(session_device, session, hass))
File "/config/custom_components/smartbox/model.py", line 407, in create_smartbox_device
await _device.initialise_nodes()
File "/config/custom_components/smartbox/model.py", line 56, in initialise_nodes
session_nodes = await self._session.get_nodes(self.dev_id)
File "/usr/local/lib/python3.13/site-packages/smartbox/session.py", line 303, in get_nodes
nodes: Nodes = Nodes.model_validate(response)
File "/usr/local/lib/python3.13/site-packages/pydantic/main.py", line 627, in model_validate
return cls.__pydantic_validator__.validate_python(
obj, strict=strict, from_attributes=from_attributes, context=context
pydantic_core._pydantic_core.ValidationError: 12 validation errors for Nodes
nodes.0.lost
Field required [type=missing, input_value={'name': 'KITCHEN', 'addr...'level': 0, 'parent': 0}, input_type=dict]
For further information visit https://errors.pydantic.dev/2.10/v/missing
nodes.1.lost
Field required [type=missing, input_value={'name': 'LIVING ROOM 2',...'level': 0, 'parent': 0}, input_type=dict]
nodes.2.lost
Field required [type=missing, input_value={'name': 'SITTING ROOM 2'...'level': 0, 'parent': 0}, input_type=dict]
nodes.3.lost
Field required [type=missing, input_value={'name': 'SITTING ROOM 1'...'level': 0, 'parent': 0}, input_type=dict]
nodes.4.lost
Field required [type=missing, input_value={'name': 'LIVING ROOM 1',...'level': 0, 'parent': 0}, input_type=dict]
nodes.5.lost
Field required [type=missing, input_value={'name': 'ALISS BEDROOM',...'level': 0, 'parent': 0}, input_type=dict]
nodes.6.lost
Field required [type=missing, input_value={'name': 'LANDING', 'addr...'level': 0, 'parent': 0}, input_type=dict]
nodes.7.lost
Field required [type=missing, input_value={'name': 'ROBS BEDROOM', ...'level': 0, 'parent': 0}, input_type=dict]
nodes.8.lost
Field required [type=missing, input_value={'name': 'UTILITY', 'addr...'level': 0, 'parent': 0}, input_type=dict]
nodes.9.lost
Field required [type=missing, input_value={'name': 'OFFICE', 'addr'...'level': 0, 'parent': 0}, input_type=dict]
nodes.10.lost
Field required [type=missing, input_value={'name': 'STUDIO', 'addr'...'level': 0, 'parent': 0}, input_type=dict]
nodes.11.lost
Field required [type=missing, input_value={'name': 'End Bedroom', '...'level': 0, 'parent': 0}, input_type=dict]
I see where is the problem, the patch is on the way
It should be good, you need to restart home assistant to see the changes
