Having issue with choose input_datetime as condition and trigger
I have an automation that updates the african_sunrise and african_sunset inputs every morning (Mozambique more specifically).
Then a separate automation (snippet) below is to turn on/off the lights as needed.
Turning on works as expected, but turning off the automation is triggered but doesn’t pass the condition to turn off the lights. I added a failsafe that runs every 15minutes to catch this for now, but defeats the purpose of the dynamic end time (minutes /15 ).
- id: '1601060469999'
  alias: M Light Cycle
  - platform: time_pattern
    minutes: /15
  - platform: time
    at: input_datetime.african_sunrise
  - platform: time
    at: input_datetime.african_sunset
  condition: []
  - choose:
    - conditions:
      - condition: time
        after: input_datetime.african_sunrise
        before: input_datetime.african_sunset
      sequence:
      - service: switch.turn_on
          entity_id:
          - switch.m1_outlet
      - delay: 5
          entity_id:
          - switch.m4_outlet
    default:
    - service: switch.turn_off
        entity_id:
        - switch.m1_outlet
    - delay: 5
        entity_id:
        - switch.m4_outlet
  mode: single
- id: '1608696862576'
  alias: Setup Time Triggers
  description: ''
  - platform: time
    at: 01:00:00
  - platform: homeassistant
    event: start
  condition: []
  - service: input_datetime.set_datetime
    data_template:
      time: '{{ state_attr(''sensor.mozambique_sun'', ''sunrise'') }}'
    entity_id: input_datetime.african_sunrise
    data_template:
      time: '{{ state_attr(''sensor.mozambique_sun'', ''sunset'') }}'
    entity_id: input_datetime.african_sunset
  mode: single
From the image you can see what the two input_datetimes are set to, and you can see that the outlet turned on at the correct time, but went past the sunset time and was turned off with the failsafe /15 trigger. I’m hoping I missed something simple in how choose interacts with time conditions and input_datetimes. Another set of eyes and/or things to try to fix the issue would be greatly appreciated.
