I have two esphome esp32 devices that show as unavailable after a restart and I then have to delete them from integrations and then readd them.
They are the only esp32 devices I have the rest are all esp8266, so I wonder if I am missing something obvious?
esphome:
platform: ESP32
board: esp32dev
logger:
# Enable Home Assistant API
api:
ota:
password: "xxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.150
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "School-Reminders"
password: "xxxxxxxxx"
captive_portal:
esp32_ble_tracker:
text_sensor:
- platform: homeassistant
entity_id: input_text.boys_school
internal: true
on_value:
then:
- logger.log: "Hello World"
# Formatted:
- logger.log:
format: "The school reminders show as %s "
args: [ 'id(school).state.c_str()' ]
i2c:
sda: 21
scl: 22
display:
- platform: lcd_pcf8574
dimensions: 20x4
address: 0x27
lambda: |-
std::string str = id(school).state;
std::vector<std::string> v;
char * token;
char seps[] = ",";
token = strtok (&str[0],seps);
while (token != NULL)
v.push_back(token);
token = strtok (NULL, seps);
int n=0;
for ( std::string s : v ) {
it.printf(0, n,"%s", s.c_str());
n++;
switch:
- platform: gpio
pin: GPIO4
- platform: gpio
pin: GPIO13
- platform: gpio
pin: GPIO15
- platform: gpio
pin: GPIO14
- platform: gpio
pin: GPIO16
- platform: gpio
pin: GPIO17
- platform: gpio
pin: GPIO18
- platform: gpio
pin: GPIO5
- platform: gpio
pin: GPIO23
- platform: gpio
pin: GPIO19
- platform: gpio
pin: GPIO26
- platform: gpio
pin: GPIO25
binary_sensor:
- platform: gpio
filters:
- delayed_off: 500ms
pin:
number: GPIO33
inverted: true
mode:
pullup: true
input: true
Thanks in advance
