I am trying to get an automation to work that would send 2 variables to a shell command, then use the response variable in conversation.
Everything seems to be working with the exception of passing the variables. I can see in the trace where the trigger.slot variables are set, but I can’t get them to send to the shell command.
alias: Get Player Number
description: ''
triggers:
- trigger: conversation
command:
(who's | who is | whose | who was) [number] { playerNumber }
(for|on|in|with) [the] { teamName }
conditions: []
actions:
- action: shell_command.get_player_data
metadata: {}
number: "{{ trigger.slots.playerNumber }}"
team: "{{ trigger.slots.teamName }}"
response_variable: message
enabled: true
- set_conversation_response: "{{ message['stdout'] }}"
enabled: true
mode: single
The trace for the automation shows the variables I am trying to send in the sentence, but blank for what gets sent to the shell command.
this:
entity_id: automation.get_player_number
state: 'on'
attributes:
last_triggered: '2026-04-30T14:02:27.644885+00:00'
mode: single
current: 0
friendly_name: Get Player Number
last_changed: '2026-04-30T13:50:31.363581+00:00'
last_reported: '2026-04-30T14:02:27.859159+00:00'
last_updated: '2026-04-30T14:02:27.859159+00:00'
context:
parent_id: null
user_id: null
idx: '0'
alias: null
platform: conversation
sentence: ' Who''s thirty-seven on Carolina?'
details:
' playerNumber ':
name: ' playerNumber '
text: thirty-seven
value: thirty-seven
' teamName ':
name: ' teamName '
text: Carolina
value: Carolina
slots:
' playerNumber ': thirty-seven
' teamName ': Carolina
device_id: 7176d37021b8f1da66199024dabc4649
satellite_id: null
user_input:
text: ' Who''s thirty-seven on Carolina?'
context:
parent_id: null
user_id: 7d65a15113734c1bb7964c4610ecbd59
conversation_id: 01KQFB534D350J0H57Y50FZCAN
satellite_id: null
language: en
agent_id: conversation.home_assistant
extra_system_prompt: null
But what gets sent to the shell command
Shell Command 'shell_command.get_player_data'
Executed: April 30, 2026 at 10:02:43 AM
Result:
params:
domain: shell_command
service: get_player_data
service_data:
number: ''
team: ''
target: {}
running_script: false
From the threads I’ve read while searching this, I thought this would work. The shell script runs, and I get my response text, but without the variables being sent the curl script doesn’t get what it needs. I’ve tested with hardcoding the variables, and that sends the commands and gives expected results. I just can’t seem to figure out what I’m doing wrong to prevent the variables to get sent from the conversation. Any help would be greatly appreciated, and if I need to provide any other information, please let me know.
