HC-SR04 in Postbox
I am a newbie in HA. short to the project. I would like to install a HC-SR04, on a d1 mini with tasmota, in a post box, so that I get an info if it is full. Values in HA ​​are already shown to me. I do not, however, realize that the correct status is displayed to me. it is always displayed fully
#postkasten
    sensors:
      postkasten:
        friendly_name: "Postkasten"
        value_template: >-
          {% if is_state('sensor.sonoff_sr04_distance', '> 10') %}
            leer
          {% else %}
            voll
          {% endif %}
        icon_template: >-
            mdi:email
          {% else %}
            mdi:email-check
          {% endif %}
Thanks!
is_state only supports an exact match, not a comparison. You need something like
{% if state('sensor.sonoff_sr04_distance') | float > 10 %}
And, have a think about using a binary template sensor instead, if you just want to distinguish two states. Maybe with device class “occupancy”?
try this:
#postkasten
    sensors:
      postkasten:
        value_template: >-
          {% if states('sensor.sonoff_sr04_distance') | int > 10 %}
            leer
          {% else %}
            voll
          {% endif %}
        icon_template: >-
            mdi:email
          {% else %}
            mdi:email-check
          {% endif %}
Your code tries to compare a string to a number. you need the | int to convert a string to a number
thanks lolouk44. that works perfectly!
