Home Assistant integration for HDANYWHERE MHUB systems.
The goal is simple — bring proper, clean control of MHUB directly into Home Assistant without workarounds.
What it does:
• Auto-detects MHUB model, inputs, and outputs
• Creates clean entities for each zone
• Source routing per output
• Volume + mute control
• IR and CEC support per zone
• Proper device grouping inside Home Assistant
• 100% local control (no cloud)
Everything is handled through the UI (Config Flow) — no YAML needed.
Still actively developing and improving it — especially around UI, responsiveness, and expanding control features.
Repository:
If you’re running an MHUB setup and want proper integration into Home Assistant, definitely give it a try.
Happy to hear feedback ![]()
